Draw
Draw 0.3.0
ottawafro
Was looking for a way to change the tool number with a Move Action filter.. The field is not editable and doesn't put permit to change the tool number. Was able to overwrite the tool # in Advanced Scene Switcher to switch tools, was wondering why the move action filter is not able to edit / manipulate this field.
DonF
Hi,
Since updating to version 2.4.0 of Draw, OBS no longer launches at all on my Ubuntu 24.04 system: the application crashes immediately at startup, making it impossible to access the interface or settings.
munchman
Fantastic. Draw has opened up new possibilities for me in lessons, so thank you!! Couple of questions if I may as I am just getting used to adding to workflow: Q. I am using Draw on my external monitor iPad with a pen. The pen activates everything on the upper toolbar except the drop down for the tool choice.
Also, if i click on anything on my main monitor Draw disappears on the iPad until i click the obs again...I tried always on top but not making any difference. Is there a manual I should be reading? Sorry if these are stupid Qs. Love it
munchman
ignore this, I think I have solved
Love the plugin. My only gripe is that the dock is always on when starting up OBS, even though I've hid it after I used it. Would this be fixable?
Thanks for the great plugin!
I just wrote on your shaderfilter board telling you that it's not showing in effects and now draw isn't either. This is an OBS nightmare for me. LOL. Any help would be appreciated.....I haven't tried a restart of my mac yet, it will need to wait till tomorrow. I pray that fixes it.
Exeldro
@Want To Learn draw and shaderfilter are not trying to load in the OBS log file so they are not installed in the correct folder. Can you find the plugin in ~/Library/Application Support/obs-studio/plugins ?
Fortunately, my schedule changed at the last minute so I can work with you now. Yes, the plugins both show up there. However, they are the only two out of three I've installed so far. Are they in the wrong place? Thanks.
Repeating what I said in shaderfilter in case you come here first: Thanks so much for telling me they might be in the wrong folder. I went in search of the right folder and found it. I put them and composite blur in the folder that has working plugins and now hey all work! I know nothing about software, but have learned a few tricks while trying to install things over the years. You ROCK! show package contents - contents - plugins (this folder.) Thanks for all you do!
DonF
I am experiencing a critical issue with OBS Studio 31.1.1 on Ubuntu 24.04 LTS. OBS crashes completely when loading the Draw Dock plugin, with the following error message in the logs:
21:43:58.156: Failed to load 'fr-FR' text for module: 'draw-dock.so'
21:43:58.156: [Draw Dock] loaded version 0.2.4
After this, the application stops working entirely. The crash occurs consistently at startup as soon as the draw-dock plugin is loaded.
It's important to note that the previous version of the plugin worked perfectly with the same OBS version and system configuration.
S7EVIN
you should make a PRO version with more feature like: timer on draw. wich chek box and time draw and disipear after say 5 sec. disipear all at once or disipear as as it was drawed. also holding a hot key will ignore the timer check box and the draw stay ther until use clear button. any hot-key or macro for all clear or swap color?
can be used with graphic tablets like XPen? So i can play my game with the mouse and use the pen on the graphic to draw.
i like your app. i dont make my donation yet i just started used it 30 min ago. i compare to see if work better than my green chroma and Xpen grafic tablet and see if do the job on my type of work.
PD: ohh i can add screen capture to this post. nice.
T-major
Hey, got this and it works great! However the "custom cursor size" option does not seem to work and it is always linked to the brush size. Using most recent OBS (31.1.2). Anyone else having this issue/know a fix?
Is it possible to add a “hilite rectangle” (or oval) wherey the shape you draw not only gets a color outline, the area outside the shape gets “dimmed”, thus creating a “hilite” effect.
This also known as a “lowlight” effect, because it affects the area you do not want highlighted.
