Draw
Draw 0.3.0
@Want To Learn It should only restore to full screen when closed full screen. Does the reset docks menu option in OBS help?
Mr. Exeldro, Thank you for your quick reply. I should mention that I do see that that you can close it by one of the colored dots that are standard with the mac on the upper left of the window. I just reset docks, closed out of it then opened it up, but it still opens with a full screen that I need to close out of with two steps. I go to the fullscreen option to make it smaller then find the option of one of the colored buttons to close it out. I would send you a log file, but I don't think it would come up unless you think it would help. Thanks......edit: I just opened OBS, clicked out of the first window in preview mode, so it came up. full screen.
@Want To Learn I added an option to reset the dock from the draw settings menu.
When logged into GitHub you download the test build from the bottom from the page:
Can you test if that helps with your issue?
I would be honored to.....I will do it now and get back to you. Thanks......update: I downloaded and installed draw dock mac universal. It opened up in full screen with OBS loading in, but I saw the new option to reset docks, so I did and it went away. However, OBS came out in preview mode, so I clicked it to go get out of the preview screen that showed nothing then draw loaded in full screen again. The positive thing is I can include it in the docks to be resized as part of the docks. Now in docks I just clicked the x to close the window.......I just opened OBS and no DRAW until I seleted it in docks. I think what did it was clicking the x to close it. Success!!!! I was trying to give you a real time explanation of how it happened in the order that it happened. So sorry if I was long winded and confusing. You are so kind to be doing this showing you care about your plugins to help people achieve their goals. Thank You!
fernavliz
hello there, first time on OBS forums, I don't know if this is the right place. First, I want to say that this plugin is awesome, I have been using this on my streams, its pretty cool.
However, I don't know why this happens, but recently, if I am during a stream, and then I push the "clear" button, my OBS crashes and of course it stops my stream too as a consequence. I'm using windows 10, and my OBS version is 31.0.1. What I do is when I need to erase is that I use the erase checkbox and then I draw a big rectangle. idk if anyone else has this problem. I don't know what causes this, and I'm not skilled enough to display this problem in a useful way to show what causes this exactly.
Lindworm
Hallo dear Sir, first of all I love all your plugins, your work is just awesome. Where can i drop gratitude in form of money?
I am using OBS in a large professional environment and I would have some feedback (and feature requests) to draw from some pro Streamers.
I am not deep enough into OBS Plugin development to just give you some pull requests.
Are you interested in their thoughts?
Please keep on being so awesome! I love your work soso much.
Lindworm
Hi, I will for sure drop you some and agitate my employer to also do so. Draw is one of the best adopted plugins by users, I have ever experienced. Within the last 4 weeks I onboarded 24 Streamer to our system and all were amazed, as they know that such a system in professional broadcast is very expensive. All told me that it is close to perfect. That this is possible within OBS directly blew there mind
The top Feature request are:
- pre defined shapes (arrows, elipses, circles, rectangles) to drag and point
- having a keyboard shortcut for activating those shapes and the lines individualy, mouse movement is to be prevented as much as possible and only used to highlight content.
- lesser feature request: adding small custom png pics for overlay (for example to put up a funny meme while casting)
For details about who we are and what we do, I can only offer dm as i am bound to public nda.
You are right about this plugin, but his move transition is right up there to. Exeldro is a legend and his plugins are the best! He also makes sure they are easy to install to!
Lindworm
You got me a tad wrong :-) move is the most valuable and the greatest plugin. But thats used by me, the template designer. Draw is the most user adopted function.
Didn't want to come over the wrong way, my OBS friend. I just wanted to slip in some more praise for Exeldro! That's all.
Lindworm
I have tried to work with draw on an external android tablet.
I found 2 "errors"
  1. This problem is also also described by another user, that on release of the pen with the line, it jumps x0 y0 while drawing
  2. the color chooser always opens on the main screen, not on the screen draw is on, this confuses users.
Rodrigods
I was hoping you'd create something like this!!
That said, the shader adds a blue tint to my video and hangs OBS as soon as I let go of the mouse button at the end of drawing a line.
Mac OS 15.3.1
OBS 31.0.1
Thanks a lot for sharing! I loved this plug in. I have the same problem.
Ventura 13.7.5
OBS 31.0.2
The option that worked just for a short period of time was the "universal installer" then it crashed. I deleted the plugin to reinstall it again but it didn't appear in Docks anymore.
Thanks for helping.
