Draw
Draw 0.3.1
What happened to the Cursor Image? It used to be an excellent feature. No cursor is shown at all, except for a tiny temporary image in front of a drawn line or pencil.
Hello, i have feedback/a bug to report: i can't draw on the full picture/screen, the available area is like a "720p" area inside the "1080p" full, i don't know how to explain it
i'm on the most recent version of obs as time of typing (32.0.1) and the most recent version of the Draw dock
Amazing plugin, thank you!!
Stamps don't seem to obey opacity rules? Or I'm likely missing something? :D
cheers!
Having an issue where after reinstalling OBS, draw dock doesn't seem to register any input from my mouse (for drawing, can still switch tools and settings.) Tried it full screen, docked, windowed, unsure how to solve this, is there any solution you could imagine?
The newest update seems to have broken custom cursors. Cursor images seem to be forced to scale with brush size, changing the size of the cursor via the 'cursor custom size' to the max of 99px doesn't work, nor does using a larger image as the cursor.
But changing brush size does increase the cursor size.
will there be an update to make the drawing work on Aitum Vertical? It can technically be done using the global draw source but the window is solid gray and it's extremely difficult to start a drawing in specific areas
I am on Mac and I'm trying to download the the plug-in, but despite the fact that I've downloaded it multiple times and done the whole installing process it is not appearing
I cannot get this plugin to show up in the Docks menu. I have tried installing this plugin multiple times and putting it in every possible obs studio folder. OBS Version is 31.0.3. I tried following every possible Youtube tutorial on how to install a plugin, but none have worked. Anyone have any other ideas? I would appreciate it.
Hey, I am using Bazzite and have OBS installed via Bazzar (Flatpak I Guess).
When I download the linux version of the drawdock plugin I only get .deb files and can't install it.
Is there any way to install this plugin?
the Internet tells me to manually extract but the debfiles do not seem to contain the rquired ata structure.
Best regards
great plugin. thanks!
there is a problem with elgato stream desk: you can't assign show/hide/clear to a button, OBS plugin doesn't provide such an option. Using system hotkey doesn't work too: it is ok ONLY when OBS window is active, but if you open plugin window, hotkey in elgato stops working. It's only elgato problem, system hotkey works fine but when you control the stream via streamdesk it's very inconvenient to use keyboard.
And maybe adding an option to hide Draw window AND clear (one button - one click) is a good idea. On small screens draw window takes place and it's good to hide it. But when you do so you can forget to clear draw layer and stream with all your drawings across new slides(
* elgato problem on mac os, doesn't use windows, maybe it works there
Any plans to update it so that the dock doesn't always open when OBS does? Every time I open OBS, draw opens in fullscreen and I have to close it.
Hope I'm not being annoying by mentioning this again, just curious if it'll ever happen. iirc having Draw in windowed mode doesn't have it open up when you boot OBS, but having it set to fullscreen does. It'd be nice if it was just tucked away until clicking it or using the hotkey to use it.
