Draw
Draw 0.3.0
StefenTower
Love the new update. The only nit I have is when I select 'Image', the button to the right for selecting an image wasn't obvious. But this might have been due to my chosen color scheme. At first, after selecting 'Image', I thought "now what?", and after a bit, I realized there was a select button there.
NikoGaus
Hello Exeldro, I have a small bug with hotkey. Every time I restart OBS, I loose the Draw Clear hotkey and I have to reconfigure it. Any thoughts?
Otherwise, this plugin is amazing!
Thank you!
Lindworm
@Exeldro I just tried the new version of the draw plugin, and it is amazing. Appart from the hotkey bug, I found it so much more intuitive. I love the projector to have it always on the touchscreen input. The fav bar is perfect.
I still need to play with the draw in scenes and with the images and stamps.
I am so amazed. This is such a good plugin. I can not praise you enough.
Thank you
ENJERUNE
At first i thought this plug in would just be a simple drawing plug in, but i was surprised to see that it works with pressure sensitivity of my drawing tablet too!! So the plug in is amazing as it is.
I dont expect the plugin to be a full on drawing program, but i think so far my only issue with it is that using the draw source from the interact button of the source does not make use of the pressure sensitivity and also the undo comand seems to be inconsistent between the interact window and the draw dock, but that last one can be worked around by asigning the same "shift + z" hotkey to the undo in the draw dock.
i dont see it as a big deal, i can picture the interact button as a quick drawing mode with less options but easier to quickly put on screen to doodle something really quick. But consistency with the pressure sensitivity would be apreciated
Regardless the plug in is awesome and you did a wonderful job with it as always, Exeldro.
Gormm
Properties such as tool type and size and cursor size are not saving for me (using OBS 31.03 and Draw 0.2.3).
I agree with the other poster that a hot-key to open the interact window would be great!
Otherwise, this is very useful.
Exeldro
@Gormm Are the tools you add to favorite not storing or the last selected in the draw dock or the last selected in source properties? Are the hotkeys to show and hide the draw dock or window not what you are looking for?
Gormm
I selected my preferences in OBS using properties for the Draw source.
When I restart OBS the tool type always reverts from rectangle to pencil and the size for the tool and cursor change to default too.
Gormm
I discovered that my settings will save if I place Draw in a Group.... but when I do that my hotkey to clear doesn't work.
Gormm
Yes, me again... I just ungrouped Draw and now the settings saved and my clear hotkey works.
So, everything works now. But obviously that isn't the preferred behavior. But maybe that work-around may help someone with the same issues.
Thanks for creating this add-on!!
patrickbaltieri
hello Exeldro, your plugin is fantastic.
I am in Obs 31.0.3 and can use the DRAW perfectly.
Whem I change scene colletions OBS crashes and send a message that is atthached.
I atthached the obs log file. The crash does not generate an error report.
I tested in a clean OBS installation and when the DRAW plugin is istalled, the problem occurs.
If I remove the plugin, the error did not appears.
I don't know if anybody else have this issue.
  • 2025-05-13 17-44-34.txt
