Scale To Sound
Scale To Sound 1.2.5
DaveBassWindu
The directory should be like this
/Library/Application Support/obs-studio/plugins/scale-to-sound/bin/scale-to-sound.so
/Library/Application Support/obs-studio/plugins/scale-to-sound/data/default_move.effect
Have you installed it correctly?
I re-downloaded it and unzipped it to /Library/Application Support/obs-studio/plugin_config.
I don't have a plugins folder. Now its not even showing up in the filters section.
mjgallant
Feature requests:
1. Bandpass filter so that only audio in a certain range is used to compute the scaling. This would be useful for “hearing” only the kick drum.
2. Control other properties besides scale, like opacity, hue, etc.
El_JeFenix
Hey! saw your filter from Activater, I have an Elgato Wave 3 mic, when I try and add your filter, my webcam (Logitech Streamcam) doesn't show the image anymore, I don't know if its caused by the Wave 3, or if its something based off how I installed it?
dimtpap
Feature requests:
1. You could duplicate an audio source and make it not output to your stream and add filters on that
2. You can control everything with sound using the "Audio Move" filter in Exeledro's Move Transition plugin
dimtpap
Please post a log file
Jec210
When I used Scale to Sound on my windows it works perfect, but on my Mac it doesnt work. when I add the filter to an image or whatever, its makes the image disappear. why is that ?
dimtpap
Other Mac users have reported this and it was the result of an incorrect installation. Make sure you installed it correctly in /Library/Application Support/obs-studio/plugins If the plugins directory doesn't exist, create it.
If you do have it installed correctly post a log file
kture
I am having similar problems as others have had here. I apply the plugin to a jpeg/png source and the source disappears or goes entirely black. Can you help me? Such a dope plugin and it would give my podcast the pop that I am looking for, but I can cannot get scale to sound to work. Help someone? Even when I apply and restart, the sources are still rendered invisible.
dimtpap
KlutchPotato
Really wanting this Plugin to work, it seems super cool. Installed this today, it showed up in my list of filters but when I add it to my source the source becomes invisible. I am running Windows 10 on a 64bit system. I tried this on a separate machine with a fresh install of obs and had the same issue. I posted this as a review as well I am sorry for that, I did this before discovering the discussion section.
dimtpap
Having an issue after downloading and putting in the OBS folder. It's showing up in OBS and can add it as a filter but when I do the image disappears and when adding an audio source it doesn't work at all. Any ideas?
Open OBS and reproduce the issue (add the filter to a source). Then go to "Help" at the top of OBS's main window -> Log Files -> Upload current log file. Click the button to copy the URL and paste it in a reply here
