Scale To Sound
Scale To Sound 1.2.5
Densle
It looks like in OBS 30.2.2, various properties/parameters are no longer revealed.
Audio Ceiling, smoothing, and the X & Y positional alignment dropdown are missing.
They still work, though. As evident from a source I have with bottom alignment. But I can't edit it anymore.
Is anyone else experiencing this?
KrazyVenomTTV
This was working fine with OBS 30.2.2 which was on my main drive. When OBS 30.2.3 released, I decided to do fresh install and rebuild the scenes & sources, only on my secondary drive. Now though, it no longer shows in source filters. Installed as directed and nothing.
KrazyVenomTTV
I'm so stupid sometimes...It works fine again. Just have to pay attention to details.
kslen
Greetings. This plugin has worked wonderfully until the 31.1.0 update, but now seems to be glitching. :/
I've attempted dropping a fresh copy in place, but the issue persist. Either the image will not appear at all, or just flicker as if it's reacting but without scaling. Just figured I'd let you know. Hopefully it's an easy fix. :)
Iron Droog
Yep. Same problem here. Any image with scale to sound plugin that i had on my OBS now disappeared. Any new image that i add to OBS (.png .jpeg .gif) and add a scale to sound plugin is also gone. And it all started with recent OBS update to version 31.1.0 .
