Resource icon
Color Monitor 0.9.3
Martyats
Got the dock open and I see the waveform & histogram. However the vectorscope is blank and the lower part of the dock window is empty space (looks like something should be there). When I try to apply either zebra or false color directly on a camera source it goes black. All are checked in the Dock properties.
norihiro
Could you provide some more information to reproduce the issue? OS, OBS's version woul be necessary. Log file would also be helpful.
Martyats
Windows 10 21H2
OBS 27.2.4 64bit
log file attached
Several lines about color monitor not loading
Thanks
  • 2022-11-06 22-02-19.txt
norihiro
norihiro updated Color Monitor with a new update entry:
Color Monitor 0.4.4
This is a minor release of Color Monitor plugin for OBS Studio.
Changes in 0.4.4
  • histogram: Added a new feature to fix horizontal level.
  • histogram: Added a new feature to show graticules.
  • Added RPM packages for Fedora 35 and 36.
Limitation
  • Possible crash when changing scene-collection (Reported on the forum but couldn't be reproduced.), adding or removing docks. The author suggest to not add/remove docks or...
norihiro
Color Monitor 0.4.5
This is a hotfix release of Color Monitor for OBS 28 on macOS.
Changes in 0.4.5
  • Added pt-BR and ja-JP translations
  • Fedora: Fixed obs-studio dependency version
  • Fedora: Removed RPATH
Limitation
  • Possible crash when changing scene-collection (Reported on the forum but couldn't be reproduced.), adding or removing docks. The author suggest to not add/remove docks or change scene-collection while streaming or...
norihiro
Color Monitor 0.4.6
Changes in 0.4.6
  • histogram: Fixed a bug that the horizontal graticule is not correctly rendered in these scenario:
    • After changed a property.
    • Stack property is selected.
Limitation
  • Possible crash when changing scene-collection (Reported on the forum but couldn't be reproduced.), adding or removing docks. The author suggest to not...
norihiro
Color Monitor 0.5.0
This is an experimental release of Color Monitor for OBS Studio.
Changes in 0.5.0
  • Improve rendering time
    • The rendering time will improve especially for users who uses standalone sources without the dock.
    • Dock users will also have improvements in the rendering time.
    • Instead, some latency will be added because of a newly introduced pipe-line to draw the scopes.
  • dock: Moved the color space settings to ROI property.
Just in...
norihiro
Color Monitor 0.5.1
This is a hotfix release of Color Monitor for OBS Studio.
Changes in 0.5.1
  • Fixed a crash when having a color scope dock on Windows.
Just in case if you see an issue, please consider use the previous version 0.4.6.
Limitation
  • Possible crash when changing scene-collection (Reported on the forum but couldn't be reproduced.), adding or removing docks. The author suggest not adding/removing docks or changing...
norihiro
Do you know when you will update the tool for OBS 29?
I realized the dock is not working correctly when monitoring Program. I will debug it and release a hotfix.
The packages titled "OBS Studio 28 or later" are supposed to work with OBS 29 as well.
norihiro
Color Monitor 0.5.2
Changes in 0.5.2
  • Fixed a bug that the texture on the dock is not updated when selecting Program.
The version 0.5.x has a lot of changes. Just in case if you see an issue, please consider use the previous version 0.4.6.
Limitation
  • Possible crash when changing scene-collection (Reported on the forum but couldn't be reproduced.), adding or removing docks. The...
chris319
I find this very useful.
Feature Request:
Please calibrate graticule of waveform monitor in % video level, viz.:
0%
20%
40%
60%
80%
100%
Thank you.
omaralmeida
In OBS 29.1.3 64bits the color monitor plugin 0.5.2 is failing to start, it doesn't work. Tried version 0.4.4 also same error. Do you have a compatible version or solution?
norihiro
norihiro
Color Monitor 0.6.1
Changes in 0.6.1
  • Fixed a memory leak when removing a dock.
  • Fixed a potential crash when removing a dock on macOS.
Limitation
  • Not all packages/binaries are tested.
    • Windows: 0.6.1 was tested with the nightly OBS Studio.
    • macOS: 0.6.0 was tested with the nightly OBS Studio on Intel mac.
    • macOS: never tested on Apple Silicon mac.
    • Ubuntu: 0.6.1...
