I would suggest to set up a helper macro which set up various variables.Hi, this is my first time posting here.
I have one camera hooked up to OBS and I'm using this plugin for a few tasks:
- Turn off monitor after 10 mins of idle time
 - Change recording folder at change of date
 - Stop recording when camera goes offline and start after it comes online
 - Motion detection in a selected area and log it
I require help with #4.
Currently,I'm only able to log a message and not the timestamp when the macro is triggered.
What my requirement is, when the macro is triggered, save the current date and time in a variable and use that when writing to the log file.
This is my current macro. How do I get the current date and time?
Thanks in advance.
You can use those to generate the desired timestamp string.
The macro should look something like this:
You can import this example using this code:
	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
	Then you can reference those variables using the
${variable name here} syntax in various text fields throughout the plugin.So a timestamp example could look like this:
This example would result in a line similar to this being appended to the given file:
My log message happened at: 2024-2-4-0-24-32
Hope that helps!
