And when the script isn't run I have checked to see if the highlighting occurs for the action and I does not. Only the conditional part of the macro on the top highlights.
In the screenshot you shared above it can be seen that the action is not executed as "Perform actions only on condition change" is highlighted in yellow.
Unfortunately without more information I cannot really say more.
I would need a log with verbose logging enabled and timestamp when you would have expected the script to be run.
OP3
Adv. Scene Switcher provides logging data?
The plugin writes into the OBS log.
You can find those files under Help > Log Files.
But as mentioned above for the log file to be useful for the analysis of this topic verbose logging would have to be enabled first by ticking the corresponding check box on the General tab of the plugin.
Plugin version 1.22.0 doesn't save changes in scene switching priority after restart OBS Studio 29.0.2 and 29.1.1.
Sorry about that and thanks for reporting the issue!
A build with a fix should be available here in a few minutes:
(Note that you have to be logged into GitHub to be able to download it - let me know if that should be a problem)
Seamas73
There is no windows build
2. I see no color matching, only pattern. Now I could make a green pattern image, but isnt it easier to compute just checking for color ?
A build with the option to check how similar the input image is to a given color value will be available here in a few minutes:
(You will have to be logged into GitHub to be able to download it)
First you will have to select the color value you want to match (1).
Next you can adjust how similar a color can be to the given input color to still count as a match at (2).
Finally you can adjust how much of the given input image must contain the given color for the condition to evaluate to true at (3).
Let me know if this works for you / does what you expected.
Bygrilinho
Hello again! Not sure if this has been asked before, but is it possible to add a control for the "Go live" state when using the YouTube integration (when auto-start is off)?
Are you referring to the topic mentioned in this GitHub issue?
If so I unfortunately did not really have the chance to look into this.
Bairespm
Hola muchas gracias por lo que haces... te cuento que no funciona midi. No me reconoce a la rodecaster pro 2 sin embargo el plugin midimg si lo hace.. pero me gustaría usarlo desde advance scene switcher así tengo todo en una sola app pero no me la reconoce . Podrías ayudarme?
Are you trying to use the MIDI condition or MIDI action?
I assume the problem is that the device does not show up here, right?
If so can you please share an OBS log?
This might give an indication what is going wrong.
Or am I misunderstanding your issue?
Bairespm
¿Está intentando utilizar la condición MIDI o la acción MIDI?
Supongo que el problema es que el dispositivo no aparece aquí , ¿verdad?
Si es así, ¿puede compartir un registro de OBS?
Esto podría dar una indicación de lo que está yendo mal.
¿O estoy malinterpretando tu problema?
Exacto, ahí es donde marcaste.
no me muestra mi rodecaster pro 2 y trato de reconectarme y no pasa nada y lo pongo en modo escuchar y tampoco pasa nada. sin embargo en el obs midi setup plugin lo reconoce sin problemas. pero como te decía me encantaría poder hacerlo directamente desde aquí. gracias por tu tiempo. Te lo agradezco . I attach the obs log
MrGhost
Very interesting I have been sending large midi messages via Streamdeck, and now I will be changing scenes with MIDI pad presses.
Yesterday I made 9 new Macros, unfortunately, they seemed to get messed up around 6. Now I can't get 4 and 5 to work the way they did when I first made them, even if I turn off 6 - 10 by unchecking the box. Anyone know how to reset them? Do they may be have a "cache clear" or something?
Is there a xml for Forearm? When I move my forearm into range of the video source I would like to have the recognition of this body part. I see upper body, lower body, eye, face...no forearm. How do I make a xml for forearm r and forearm l.
My scene 4 and scene 5 were l and r sides of the keyboard, Should I take a new screenshot? I spent about 8 hours yesterday and they didn't work after the very inception of the 9 macros.
Unfortunately I think your attachment got lost or I am not able to find it.
Can you provide more details on what you have set up exactly?
Preferably export your current plugin settings to a file (General tab) and share it here.
Alternatively share screenshots of the macros.
It would also be great if you can provide a log file where the issue happened.
If that is feasible for you, please enable verbose logging on the General tab and provide a timestamp when the problem happened.
Unfortunately only I am not aware of any pretrained models for detection of forearms.
I am only aware of the following:
You would either have to train your own model (which is likely too much work) or try to use pattern matching instead.
I am not sure I fully understand what you mean here.
Is this referring to the object detection or the MIDI topic?
MrGhost
Ah, it seems in copying the l side of the keyboard's macro, I forgot to switch the scene switcher portion below to the r side's scene. It took a minute or two today but I found it.
I had pretty good luck with this today, and pretty sure all 10 macros popped constantly over a 2 hour live stream. Of course a few are only used for very limited directional camera sources so they may not be visible popping so to speak, but many of the other scenes can be seen flashing sometimes too quickly. This was my first attempt at a live recording with these and I think it went fairly well. Is there any place where such videos are welcome? I posted my music recording online but I don't know how this forum is about links.
Though I didn't do the log, & there are probably improvements I can make. I was pretty happy with the results.
Bairespm
sorry now attach file
  • 2023-05-21 21-47-14.rar
