Just got around to trying it. Looks like everything worked except uploading to GitHub:
Ah sorry about that - the link I posted earlier was not quite correct.
The build artifacts are only available on the "summary" screen on GitHub.
That's better! But it doesn't seem to work for me.
It took a long time to find. Your screenshot only shows "Plugin state", whereas mine is here:
That's fine I guess, as long as it's in there *somewhere*.
But then it doesn't actually close. The popup confirmation works:
But it doesn't actually close unless I click Yes *within* the 10 seconds. Clicking Yes *after* the timeout is the same as No.
I really had in mind that it would be unattended by the time this happens. The opportunity to cancel is a good idea, but more important is to actually close with no one there.
Would this be possible?:
  • Clicking Yes closes immediately
  • No response closes after 10 sec
  • Clicking No keeps it open
Thanks!
Thanks!
That is how it was intended to work and how it does work in my development environment.
I can however confirm that this does not work on the official OBS releases for some reason.
I will try to investigate - thanks a lot for letting me know!
(Btw. I don't know why your locale files seem to be broken - I could not reproduce that problem with the release above)
Update:
It seems to work reliably if the dialog displaying the message is not modal / blocking input to the OBS window.
I have no idea why this works in the development environment however.
But please confirm if this also works for you - a build should be available here in a few minutes:
Update:
It seems to work now...but I got a TON of crash messages for a bunch of different graphics-related services. (KDE Plasma) The OBS window itself did not close except for when it was supposed to, so that logic works, but it's still included as one of the things that crashed.
Repeating the test, without rebooting first, didn't have any crash messages at all.
The locale has not changed.
Edit: Rebooted, and I still can't reproduce the crashes.
Is "PREVIOUS SCENE" always crashing OBS for anyone else? I stopped using Bar Raiders' app entirely because of this - it was the only thing they had that no one else did - till I discovered Advanced, but now Advanced' "Previous" scene always crashes it - always.... Not sure if this is from a new update or if OBS is just fighting this hugely obvious option that should be built into their software anyway.... I am deleting all of my Previous Scene commands as of now....
Also - for the record - I have a 4090 i-13 128gb DDR5 computer, new, with fresh OBS, etc.... My older 3070 had all sorts of issues with plugins - but I've only added more "Trusted" ones from people like Exeldro, Warm, etc
Works for me:
This is for a "presentation style" remote meeting. The Previous Scene is assumed to always be a camera. If not, this needs to be paused and something else set up beforehand. For its intended purpose, it still works perfectly, across several updates.
Can you please share a crash log?
That could indicate where the problem is.
JaysJams
ASS 1.21.1 is simply too complicated. How do I get it back to an earlier version? I just want "A" to "B" after xx seconds. TIA!
Just uncheck this box on the General tab.
Alternatively have a look at these examples:
Let me know if you have questions!
CastleWaco
I have a pair of push-buttons and a makey-makey board for a game I’m working on. Could I use Advanced Scene Switcher for a lockout first-button-pushed scenario? I’m hoping to find something that resembles a hotkey, but works only inside one scene instead of globally.
You could do something like this:
You can expand that to as many buttons as you like, plus one more macro that unpauses all of them.
The caveat though, is this:
If the buttons are closer than that, then they take priority in the order that the macros are run.
A more effective way to do this might be to use a physical circuit to detect the first button press - lots of those available through a google search, and they're also used for pinewood derby tracks - and then take your time, comparatively speaking, to translate that into a keypress on a custom keyboard.
(I just took a membrane keyboard apart to try and fix a problem with it. It looks incredibly easy to inject a keystroke into: it has two conductive layers separated by an insulating layer, that has a hole for each key. Connect the conductive layers through that hole, and that's a keypress.)
Or an Arduino variant with native USB might do all of that. (not all do: some have a USB to serial converter on-board, and the CPU chip itself only has serial; that will not work for this) Set it up to be a keyboard on USB, and then your sketch runs a tight loop watching for any button. As soon as it sees one, stop scanning the buttons and decode that one to send as a keystroke.
If you have up to 8 buttons on an 8-bit variant, this becomes easy: accept some weird-looking wiring if necessary to put them all on the same 8-bit port, which can be read all at once. Wait for that port to not be 0 (or 0xFF (255), depending on how you've wired it), then decode the one different bit. If multiple, use a priority scheme, which will probably come naturally from the way you write the sketch anyway, or random to make it more "fair" but takes some extra work on the programming side. Likewise for up to 16 buttons on a 16-bit core, or up to 32 on 32-bit.
Either way, the "only on a specific scene" part is still handled in Adv. SS as above.
TazChris94
I am having issues with the Media Source option. The media source I have is just a 5 minute countdown timer. When it ends, I would like for it to switch to a default scene. But the issue is that it will switch to the default scene at any time, Since I have really looked into it, it is been after about 5-20 seconds. Below is a screen shot of the settings and macro. It is the only macro I have setup currently. I also tried the verbose logging, but cannot find the logs. Any thoughts on why this is?
I'd do this:
Notable differences are:
  • Only on change
    • I use this for everything! It ensures that the macro only runs once when the condition becomes true, instead of continuously while it's true.
  • Any source on Current Scene
    • This works regardless of what you add or remove later, so you don't have to keep coming in here and changing the macros. If you have multiple videos and you only want it to do this for one of them, then you would still specify the exact one, instead of Any on Current.
  • Playing and less than X time remaining
    • This gives it X time to figure out that the condition is true (check your scan interval on the General tab), but it's usually pretty quick about it.
    • Ended has always been somewhat vague to me. Does it have to have been playing first? Or is it *always* Ended, except for when it's playing, even if it hasn't played at all yet? Depending on the answer to that, is the Ended signal short enough to be missed sometimes? Playing and almost done, doesn't have that ambiguity.
  • Transition over the same X time
    • This gives a nice professional look, as the video is practically over anyway, and the last X time of it is still playing during the transition. That gives the impression that it could have gone on longer, but you made a production decision to end it there. In other words, you appear proactive instead of reactive.
videored
Is there a way to set a variable to a fixed value based on what's written inside a .txt file? I keep track of certain stuff in a single line in a .txt and it would help me a lot (Considering that I've seen this can do the opposite already, modify a .txt file).
I think something similar to this should do what you want to achieve.
It assigns the content of a given file to a variable.
TazChris94
I'd do this:
  • Only on change
Thank you for the information. I actually found that in the general settings section, that 'if no actions performed for x seconds' was set to switch to a scene. I set this to do not switch and it fixed the initial issue. But I also discovered that ended is ended, and it was thus running each time. So, your solution makes sense and should work without issue.
Chris
