Question / Help VirtualCam Tool crash when I go to "Horizontal Flip" checked !!
minhphat266
Log file:
19:24:25.712: CoInitializeEx succeeded: 0x00000001
19:24:25.712: CPU Name: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
19:24:25.712: CPU Speed: 2294MHz
19:24:25.712: Physical Cores: 2, Logical Cores: 4
19:24:25.712: Physical Memory: 6043MB Total, 2763MB Free
19:24:25.712: Windows Version: 6.1 Build 7601 (release: unavailable; revision: 24545; 64-bit)
19:24:25.712: Running as administrator: true
19:24:25.712: Aero is Enabled
19:24:25.713: Current Date/Time: 2020-04-09, 19:24:25
19:24:25.713: Browser Hardware Acceleration: false
19:24:25.713: Portable mode: false
19:24:26.460: OBS 25.0.1 (64-bit, windows)
19:24:26.460: ---------------------------------
19:24:26.482: ---------------------------------
19:24:26.482: audio settings reset:
19:24:26.482: samples per sec: 44100
19:24:26.482: speakers: 2
19:24:26.483: ---------------------------------
19:24:26.483: Initializing D3D11...
19:24:26.483: Available Video Adapters:
19:24:26.485: Adapter 0: Intel(R) HD Graphics 3000
19:24:26.485: Dedicated VRAM: 67108864
19:24:26.485: Shared VRAM: 1711276032
19:24:26.485: Driver Version: 9.17.10.4229
19:24:26.486: output 0: pos={0, 0}, size={1366, 768}, attached=true, refresh=60, name=
19:24:26.489: Loading up D3D11 on adapter Intel(R) HD Graphics 3000 (0)
19:24:26.494: D3D11 loaded successfully, feature level used: a100
19:24:26.494: DXGI increase maximum frame latency success
19:24:27.341: ---------------------------------
19:24:27.341: video settings reset:
19:24:27.341: base resolution: 1366x768
19:24:27.341: output resolution: 1280x720
19:24:27.341: downscale filter: Lanczos
19:24:27.341: fps: 30/1
19:24:27.341: format: NV12
19:24:27.341: YUV mode: 601/Partial
19:24:27.341: NV12 texture support not available
19:24:27.341: Audio monitoring device:
19:24:27.341: name: Default
19:24:27.341: id: default
19:24:27.352: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
19:24:27.352: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
19:24:27.401: [AMF] Unable to load 'amfrt64.dll', error code 126.
19:24:27.401: [AMF] AMF Test failed due to one or more errors.
19:24:27.401: Failed to initialize module 'enc-amf.dll'
19:24:27.427: [obs-browser]: Version 2.8.6
19:24:27.454: starting virtual-output on VirtualCam'1'
19:24:27.456: Couldn't find VLC installation, VLC video source disabled
19:24:27.502: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
19:24:27.502: No blackmagic support
19:24:27.506: ---------------------------------
19:24:27.506: Loaded Modules:
19:24:27.506: win-wasapi.dll
19:24:27.506: win-mf.dll
19:24:27.506: win-dshow.dll
19:24:27.506: win-decklink.dll
19:24:27.506: win-capture.dll
19:24:27.506: vlc-video.dll
19:24:27.506: text-freetype2.dll
19:24:27.506: rtmp-services.dll
19:24:27.506: obs-x264.dll
19:24:27.506: obs-vst.dll
19:24:27.506: obs-virtualoutput.dll
19:24:27.506: obs-transitions.dll
19:24:27.506: obs-text.dll
19:24:27.506: obs-qsv11.dll
19:24:27.506: obs-outputs.dll
19:24:27.506: obs-filters.dll
19:24:27.506: obs-ffmpeg.dll
19:24:27.506: obs-browser.dll
19:24:27.506: image-source.dll
19:24:27.506: frontend-tools.dll
19:24:27.506: enc-amf.dll
19:24:27.506: decklink-ouput-ui.dll
19:24:27.506: coreaudio-encoder.dll
19:24:27.506: ==== Startup complete ===============================================
19:24:27.508: Service '' not found
19:24:27.512: All scene data cleared
19:24:27.512: ------------------------------------------------
19:24:27.543: WASAPI: Device 'Integrated Microphone Array (IDT High Definition Audio CODEC)' [44100 Hz] initialized
19:24:27.545: Switched to scene 'Scene'
19:24:27.545: ------------------------------------------------
19:24:27.545: Loaded scenes:
19:24:27.545: - scene 'Scene':
19:24:27.545: - source: 'Main Screen' (monitor_capture)
19:24:27.574: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
19:24:27.574:
19:24:36.899: Output 'VirtualOutput': stopping
19:24:36.899: Output 'VirtualOutput': Total frames output: 280
19:24:36.899: Output 'VirtualOutput': Total drawn frames: 214 (283 attempted)
19:24:36.899: Output 'VirtualOutput': Number of lagged frames due to rendering lag/stalls: 69 (24.4%)
19:24:36.903: virtual-output stop
19:24:38.141: starting virtual-output on VirtualCam'1'
19:24:41.450: Output 'VirtualOutput': stopping
19:24:41.450: Output 'VirtualOutput': Total frames output: 96
19:24:41.450: Output 'VirtualOutput': Total drawn frames: 66 (99 attempted)
19:24:41.450: Output 'VirtualOutput': Number of lagged frames due to rendering lag/stalls: 33 (33.3%)
19:24:41.453: virtual-output stop
19:24:43.240: starting virtual-output on VirtualCam'1'
Update to Windows 10. I don't believe anyone is even testing new builds of OBS on Windows 7, which is no longer supported. The minimum system requirement for OBS 25 is listed as Windows 8.
