Urgent help
yuntian
14:20:13.223: [Media Source 'media source']: settings:
14:20:13.223: input: rtmp://。。。。。。。。
14:20:13.223: input_format:
14:20:13.223: speed: 100
14:20:13.223: is_looping: no
14:20:13.223: is_hw_decoding: no
14:20:13.223: is_clear_on_media_end: no
14:20:13.223: restart_on_activate: no
14:20:13.223: close_when_inactive: no
14:22:12.317: [Media Source 'media source']: settings:
14:22:12.317: input: rtmp://。。。。。。。
14:22:12.317: input_format:
14:22:12.317: speed: 100
14:22:12.317: is_looping: no
14:22:12.317: is_hw_decoding: yes
14:22:12.317: is_clear_on_media_end: no
14:22:12.317: restart_on_activate: no
14:22:12.317: close_when_inactive: no
14:26:21.625: executable: PotPlayerMini64.exe
14:26:21.625: method selected: Automatic
14:26:21.625: method chosen: BitBlt
14:26:21.625:
14:26:25.458: executable: PotPlayerMini64.exe
14:26:25.458: method selected: BitBlt
14:26:25.458: method chosen: BitBlt
14:26:25.458:
14:26:25.991: executable: PotPlayerMini64.exe
14:26:25.991: method selected: BitBlt
14:26:25.991: method chosen: BitBlt
14:26:25.991:
14:28:53.097: [Media Source 'media source']: settings:
14:28:53.097: input: rtmp://。。。。。
14:28:53.097: input_format:
14:28:53.097: speed: 100
14:28:53.097: is_looping: no
14:28:53.097: is_hw_decoding: yes
14:28:53.097: is_clear_on_media_end: no
14:28:53.097: restart_on_activate: no
14:28:53.097: close_when_inactive: no
My media source will get stuck when streaming. I checked the parameter setting of streaming signal before, but it will get stuck when streaming in OBS. Thank you very much.
It appears that you selected some log file lines for your forum post. Please share the complete log instead:
WBE,帖子:530957,会员:238208 said:
您似乎为论坛帖子选择了一些日志文件行。请改为分享完整的日志:
[/引用]
感谢你的回复。相关问题已经找到。
