areinhiller
Hello all. I am in need of urgent help. I'm the multimedia coordinator of a church. We have a wedding at the end of the month that needs to be live-streamed, but OBS has suddenly started stuttering its audio in both recording and streaming. It worked fine for the funeral we streamed on the 8th, but for the funeral on the 10th and both services today, we had helicopter audio. The audio coming from the soundboard is fine when sampled from the board itself. OBS's audio levels show the stutter. I've searched the forums and have tried a number of different solutions, but none have worked.
I've tried:
We are using OBS 26.1.1 64-bit windows. Quicktime for Windows is installed on the computer even though the logs show the CoreAudio AAC encoder as uninstalled or not located. We stream through sermonstudio.net. I've included the log and screenshots of all our settings and devices. Any suggestions on how to solve this or is this an issue with the current version of OBS? Thank you in advance!
I've tried:
- Disabling Realtek audio devices leaving only our Blackmagic devices active
- Lowering Mic and Speaker levels to between 80 and 90
- Running the Auto setup Wizard
- Restarting OBS
- Restarting the Computer
- Making sure all audio devices are set to 48kHz
- Adjusting streaming bit rate up to 3500Kbps
- Checking all 6 audio track boxes under the recording tab of Output
- Using Simple output
