Unable to capture internal audio
Crew Capsule
So, I've been trying to make some Roblox gaming videos, recorded with OBS. However, this "Audio Output Capture" doesn't work. When I click "devices", there are no options. When I went to settings, all the devices are disabled, except for Mic/Auxiliary Audio, set to Default. All the devices only have one option, which is Disabled. Is there any way to change it? I checked my computer settings, and I can't find any settings that can allow OBS to capture the internal audio. Any help? Thanks :D
hmm... did you check the system environment -> security and privacy -> privacy -> mike -> OBS app checked?
In my case, I experienced the same case as you, but I solved the issue this way.
And another way to solve the issue is to input the command below in the terminal window
/Applications/OBS.app/Contents/MacOS/OBS;
I wish my reply helps you. :)
