Traces were found indicating that OBS arbitrarily used the application during its installation.
BSASBS
When I tried to install OBS for the first time, I got an error message saying "Close it because Google Play is using OBS." But OBS shouldn't be installed yet, so what kind of situation is it where OBS is using the application? The timeline doesn't match up, and it seems impossible, but is it perhaps trying to arbitrarily use the application during installation to extract information?
You likely have a previous version installed and the virtual camera DLL is loaded by other applications. Check the default path (C:\Program Files\obs-studio).
