Status
Not open for further replies.
IDLT
Had the same issue as Turtlebox.
I indeed simply deactivated the Blur filter.
But I think what he wanted to ask was, "Can the blur filter be updated so that at the lowest setting the blur is imperceptible."
Right now the blur seems to go from 1% to 100%, and the desired effect would be 0% (most likely a 0.0001%) to 100%, so that you can smooth transition that 0 to 1 instead of a jump in blur level.
This issue would be considered fixed once you can set the blur at the lowest setting possible, and when you flip the filter ON and OFF you cannot perceive any difference.
00hanny00
Hello. First post here. I installed the newest Flatpak version of StreamFX 28.0.2 in Linux Mint 21, based on Ubuntu 22.04.
I know it's an alpha version. It's not loading. I get this in the logs:
16:51:25.476: os_dlopen(/home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so->/home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so): /usr/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so)
16:51:25.476:
16:51:25.478: os_dlopen(/home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so->/home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so): /usr/lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so)
16:51:25.478:
16:51:25.478: Module '/home/harry1/.var/app/com.obsproject.Studio/config/obs-studio/plugins/StreamFX/bin/64bit/StreamFX.so' not loaded
Any advice would be appreciated.
What i found was, that GLIBC 2.34 is from 2021 and my distribution is on Version 2.36. I think the Streamfx should be update to the new Version.
MrAlphaTurkey
Howdy,
Just updated to OBS 28.0.3 and installed StreamFx using the .exe version 0.12.0
It seems that 3D Transform isnt working, from some digging here in the forums it seems that i shouldn't of updated!
Am I wrong? Thanks
Marugawa
Howdy,
Am I wrong? Thanks
Yeah, StreamFX for OBS 28 is currently still in alpha, so you (probably) shouldn't use it for production yet. If you want to use StreamFX you should probably roll OBS back to 27.
Xaymar
StreamFX only supports Ubuntu and Debian-like. For other Operating Systems you will have to compile from source code, or wait for a third party maintainer to provide it. StreamFX links against the supported glibc on the given Ubuntu version.
Deviaphan
It crashes when I exit OBS. When I delete the StreamFX, then there is no error. At the same time, there are no problems during operation, the filters I use works well.
Unhandled exception: c0000005
Date/Time: 2022-10-30, 11:49:12
Fault address: 7FFF75B92879 ((null))
libobs version: 28.0.3 (64-bit)
Windows version: 10.0 build 19045 (release: 2009; revision: 2193; 64-bit)
CPU: AMD Ryzen 7 5800X3D 8-Core Processor
Thread 3818: (Crashed)
0000003ACBEFF438 00007FFF75B92879 000001FC09B7ADC0 000001FC09B7ADC0 00007FFF9CA47620 000000000000001F <unknown>!0x7fff75b92879
0000003ACBEFF440 00007FFF9CA01111 0000003A00000000 00007FFF9CA47620 0000003ACBEFF4D8 000001FC09B7ADC0 obs.dll!signal_handler_signal+0x101
0000003ACBEFF4A0 00007FFF9C9F0CB6 000001FC09B7ADC0 0000000000000000 000001FC09B7ADC0 0000000000000000 obs.dll!obs_source_filter_remove_refless+0x176
0000003ACBEFF5A0 00007FFF9C9EF650 0000000000000000 0000000000000000 000001FC66661A40 0000000000000001 obs.dll!obs_source_destroy+0x160
0000003ACBEFF5D0 00007FFF9C9B2A88 0000003ACBEFFAE0 000001FC667874F0 0000000000000000 0000000000000170 obs.dll!obs_free_data+0xa8
0000003ACBEFF600 00007FFF9C9B76A3 0000000000000000 0000003ACBEFF8C0 0000003ACBEFFAE0 0000000000000000 obs.dll!obs_shutdown+0x3f3
0000003ACBEFF650 00007FF7DB0781AD 0000003ACBEFF728 00007FF700000000 FFFFFFFFFFFFFFFF 000001FC68C66480 obs64.exe!OBSApp::~OBSApp+0x5d
0000003ACBEFF680 00007FF7DB0862DF 0000000000000000 000001FC6673F1E0 000001FC00000000 0000000000000001 obs64.exe!run_program+0xc4f
0000003ACBEFF9E0 00007FF7DB0889A0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!main+0x6d0
0000003ACBEFFBB0 00007FF7DB294B57 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!WinMain+0x157
0000003ACBEFFC40 00007FF7DB2942E2 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!__scrt_common_main_seh+0x106
0000003ACBEFFC80 00007FFFC06A7034 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7fffc06a7034
0000003ACBEFFCB0 00007FFFC07E26A1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7fffc07e26a1
Talonis
I spent 18 months honing OBS 26/27 to work with a MacBook Air M1 efficiently at 1080p60 streaming. Which it now does (c. 25% CPU), so I'm happy to wait until 2023 for the very few plugins I do use (such as StreamFX) to be officially released for v. 28.
It is such a good plugin it is worth the wait.
Xaymar
There are two known bugs that could cause this crash, both have a fix being tested at the moment.
enoc_vt
Does anyone knows if Color Grading will work on OBS 28? That's the only StreamFX tool I use and don't want to wait for the stable release.
Quilombo3
As far as I can tell, yes, it does work.
I'm currently using it on OBS v28 with this last beta release, and it's working ok.
@Xaymar Thanks for the update but when trying to install it, F-Secure gave the following warning: Suspicious:W32/Malware!Deepguard.[variant] and aborted the installation. I reinstalled the version I used before (0.11.1.0-g81a96998) and got no such warning.
Xaymar
All binaries are generated by GitHub Actions from the code you can publicly see on GitHub. Most likely this is a complaint about setting environment variables or installing Microsoft Visual C++ redistributables.
chussy
Hola.
¿Podría hacer un filtro de sombreado que recopile los colores rbg de una máscara de formato webm?
Gracias.
Tenía el mismo problema que Turtlebox.
De hecho, simplemente desactivé el filtro Blur.
Pero creo que lo que quería preguntar era: "¿Se puede actualizar el filtro de desenfoque para que, en la configuración más baja, el desenfoque sea imperceptible?".
En este momento, el desenfoque parece ir del 1 % al 100 %, y el efecto deseado sería del 0 % (muy probablemente un 0,0001 %) al 100 %, de modo que pueda suavizar la transición de 0 a 1 en lugar de un salto en el nivel de desenfoque. .
Este problema se considerará solucionado una vez que pueda configurar el desenfoque en la configuración más baja posible, y cuando encienda y apague el filtro, no podrá percibir ninguna diferencia.
Talonis
I decided to pull the trigger and upgrade my OBS to 28 and Mac M1 native. The latest Mac alpha version of StreamFX seems to be working fine.
jarno527
I'm trying to install on Mac OS 13.1 and OBS 28.0.3 (64 bit on a M1). I've spent about 30 minutes and can't get it to go. I followed the installation guide laboriously, installing the latest production build (streamfx-macos-10.15-0.11.1.0-g81a96998.pkg). It goes through the install dialogue and states a successful install, but nothing appears in the plug ins folder.
I'd be glad to use this plug in if I can but I'm stuck. Thanks for any help anyone can give!
jarno527
Ok. I just installed the alpha (which I was trying to avoid) and it went great. That's my answer. Thanks!
circle
I'm trying to install on macOS Catalina but there are no options on the Installation Type step where I'm supposed to click the Change Install Location... button. I went ahead and installed, but it's not showing up as an option in OBS.
Status
