glikely
glikely updated PTZ Controls with a new update entry:
PTZ Controls 0.18.0
em que aprendo a falar português
I'm quite happy with this release. Not only does the plugin finally support localization with translations added for Portugese, Danish, German, French, and Norwegian, but there have been updates throughout the core code. Joystick buttons can now be mapped to any OBS hotkey. The VISCA protocol handling is more robust and should be better at reporting camera power and autofocus state. It is also the background work that was needed to start adding control of...
Lifendason
Thank you for the plugin, but can you tell me how to rename the cameras? I use PTZ camera with TCP and they show up as PTZ Device, PTZ Device 1.
abeltrao
Nice plugin, altough after instaling the last version, it is no longer working.
I am getting an "unable to load" plugin error, altough nothing has changed... and the files are where they are supposed to be.
- OBS 31.0.3 or 31.0.4 + Win11
14:03:30.928: Module '../../obs-plugins/64bit/obs-ptz.dll' not loaded
14:03:30.928: Failed to load module file '../../obs-plugins/64bit/obs-ptz.dll', file not found
Do you have any ideas? Suggestions?
Thanks!
glikely
Thanks!
There are two different installers for Windows. One that works with OBS 31.0.4 and newer, and one that works with OBS 31.1.0 and later. Did you install the correct one?
abeltrao
Well, triple checked the version.
At the end, i've tried to copy manually the files ... it worked after multiple attempts. Weird.
glikely
There are two common problems that I've run into with the current release:
First problem is when files from an older version still installed. You need to make sure to remove all traces of older versions of the plugin. That means clearing out the `obs-ptz.dll` and `QSerialPort.dll` files from `c:\Program Files\obs-studio\obs-plugins\64bit`. The latest version of the plugin installs to the new location of `c:\ProgramData\obs-studio\plugins`
The second problem is using the wrong installer for your version of OBS Studio. I cannot currently build a single version of the plugin that works with both OBS Studio 31.0.4 and the 31.1.0 release candidate, so there are two separate installer files.
- For OBS Studio 31.0.4 and newer use obs-ptz-0.18.1-windows-x64-Installer.exe
- For OBS Studio 31.1.0 and later use obs-ptz-0.18.1-windows-x64-for-31.1.0-Installer.exe
kindkatz
obs version 31.0.4 . Cant get it to show up in obs. Reinstall, uninstalled, tried zip. Not sure which folder it suppose to go in. Have the main install on D: that has bin,data,obs plugins and i bunch of uninstall apps. Have the appdata/roaming/obs-studio one and the programdata/obs-studio that has shader-cache and plugins with only one plugin in it, i have more installed.
