Pixel Art
Pixel Art 0.0.4
dsp-stanky
dsp-stanky submitted a new resource:
Pixel Art - Add a retro-inspired aesthetic to any source
An effect filter to add retro-inspired aesthetics to any source!
Usage
  • Right click any source (image, video, etc), and select `Filters`
  • In the filters menu, press the `+` button to add a new filter
  • Select `Pixel Art`
  • Play with settings to your hearts content!
  • The `Dithering` section will help add back in some detail after you've downscaled your source
  • The `Color Count`...
Getting a virus positive report on Windows 11 for the installer. And would also much prefer a zip version.
Hmm odd, think I might know what's causing that though, so i'll try to see if I can fix it over the weekend, as well as getting a zip version for windows. Thanks for telling me!
Phonzy Trojan included with this project on Windows:
I'm reporting you.
I talked with a few obs devs on the discord, plugins (especially ones like mine that aren't digitally signed because we don't want to shell out $100 to apple) will sometimes produce false flags for AV's, if you still don't trust the download, i can simply tell you that I'm not smart enough to know how a trojan works, let alone how to code one.
And there's zero chance I accidentally coded one.
Hi, a false positive I guess
It works weird with transparent sources
