Resource icon
OBS-VirtualCam 2.0.4
Mase
Thanks CatXfish. Is there a registery Key to make OBS the default webCam. I have tried doing within Windows devices & printers but my webcams don't show up there. I want to use it as the default cam in BluStacks. Right now I disabled the onboard webcam (DeviceManager)but it refused to use any other webCam.
mcomyford
Question... Should the "OBS-Camera" show up in Windows 10 as a device in Device Manager?
I have OBS 25.0.4 with OBS-VirtualCam 2.0.4. I have started the camera and see the log entry below:
03:00:44.352: starting virtual-output on VirtualCam'1'
But I do not see a virtual device in Device Manager for it. I ask because on Skype I do not see the option for "OBS-Camera".
Appreciate any help!
FYI... I figured out my issue. It was caused by the default version of Skype being used. I ran into the same issue with the NDI virtual cam. Once I uninstalled the built-in Skype and installed the one from the website both OBS and NDI were available.
RoamingRomans
Anyone have any luck with getting the output resolution issue resolved? On an older install of VirtualCam and OBS, I have zero problems and my output resolution via VirtualCam is 1080p. On the current one, the output is very low resolution. Any help or advice would be appreciated.
kokotron
I have the same problem as @BoukeKoning and possibly @mcomyford ... The virtual cameras won't show up in Viber, Skype, Teams, Hangouts in Firefox. BUT... they DO show up in VLC > Capture Device (the delay is horrible though). I used the installer.
Windows 10 1909, OBS 25.0.4, VirtualCam 2.0.4
Brooksons
im having same issue as @kokotron and @BoukeKoning and above, Windows 10 version 1909 virtual cam is in tools but will not show up in other programs ie teams or skype, it will not show up in device manager or the windows 10 camera app, i can't see it on websites like test my webcam, im using a cannon EOS Rebel T100, i know it works as I had it working on my other pc which is running windows 7, it would show up in the 3rd party apps as obs camera 1-4, does anyone have any idea on what we can do to work around this?
Sharper
Heya!
I used to work with virtual cam long ago, updated to Win 10 some time ago now and can't get it to work anymore. The virtual cam just won't show up in the "Tools" list, but funnily enough in Discord there is an "OBS-Camera" to choose from.
Anyone can help me get it to show up in "Tools" again? I tried fresh installing, tried manually installing it but it doesn't seem to work. When I run the regsvr32 cmd prompt it tells me that the module hasn't been found (even though it's there).
Pammy
If you're a Windows 10 user there's no point trying to get OBS Virtual Cam to work until this program is updated and the bug is fixed. Due to issues, installing this in OBS 25.0.4 won't make OBS Virtual Cam appear under "Tools". It's probably best to find an alternative program until it's fixed.
Hopefully a patch will come out soon, otherwise this program is sadly (literally) unusable.
I'm using all of those (Windows 10, OBS 25.0.4) and Virtual Cam is working for me. I had it installed in earlier versions where it also worked, and upgraded. It still works.
Pammy
I have been using OBS with Virtual Cam (great program, btw, thank you) on Skype. I would love to be able to sometimes record my calls, but I haven't found a way to do this without turning off Virtual Cam.
I use the Window Capture but I only can see and hear my side of the conversation. If I turn off Virtual Cam, then I can record both sides.
Does anyone have any ideas? Thank you!
colum3us
colum3us
I can use the virtual cam in Google Hangouts in Chrome & Firefox but in the Skype app on Windows 10 it does not show the OBS-Camera.
Joel383
Who can help me? OBS continue to crash when i start Virtual Camera, i posted the log error here
I'm having the exact same issue with vcruntime140.dll
With virtual cam installed OBS crashes on startup.
Uninstall virtual cam and OBS is fine.
With virtual cam installed, the (physical)webcam works in both Edge nor Chrome browsers for livestreaming to youtube.
With virtualcam uninstalled, the physical camera does not detect, ONLY for youtube livestreaming, in both Edge and Chrome, IT DOES detect on google hangouts, onlinemictest.com, ect.
with OBS and virtualcam uninstalled, camera works fine.
I have tried running scf /scannow
Checked the log, no vcruntime errors
HALP!
Halcon
Hi
Thanks for this great software.
However, I am also having severe problem with the resolution of virtualcam. It is extremely poor. Please, could you solve this issue?
Regards
dLxdome
Hi guys,
same from me! Great thanks for this feature.
Just a short, but maybe tricky question. I've got OBS 25.0.1 and VirtualCam 2.0.4 installed on my laptop & desktop. For video communication I'm using Skype4Business & zoom.
On my desktop everything is working fine, but however, on my laptop OBS-Camera (from VirtualCam) is only showing up as a source in Skype4Business but not im zoom. I just can select my "Integrated Cam" but no other sources. Within Skype4Business and my Browser (Chrome) it is choosable.
Maybe someone else had this problem as well or you have any ideas for a solution ?
Thanks & Regards
skypyxis
Virustotal has 2 engines detecting OBS-VirtualCam2.0.4-Installer.exe as Malicious.
These are false positives, right? Nobody had problems with this plugin before?
C0mbatW0mbat
Could someone please help me set up OBS Virtual Cam please. I am trying to capture video ( stream ) to Discord. I have installed the software etc yet when I select the source as OBS Camera all I get is a black window in OBS and Discord.
hejtumateuszeq
Hi,
I installed this plugin, but after starting OBS i can't see Virtual Cam option in my tools. I tried reinstalling obs and plugin and restarting obs, but it didn't solved my problem. I have Virtual Cam ver. 2.0.4 and obs ver. 25.0.4
The reason i'm asking this question here is because i couldn't find any solution in other forums or discussions, and thought that maybe here you could help me.
I attached my obs log for "obs-virtualoutput.dll", if needed ask for more screens cause i don't even know if that what i attached is even helpful to you :(
