OBS Studio not capturing video
TombStone
Rceently I've updated my PC's GPU & CPU but since then OBS Studio hasn't been the same.Whenever I try to record the video will show the fist screen of my art program but none of the progress I'm making. The audio works just fine and plays throughout the entire recording.
Thank you for your time.
Here is the log:
00:42:03.326: CPU Name: AMD A6-9500 RADEON R5, 8 COMPUTE CORES 2C+6G
00:42:03.421: CPU Speed: 3500MHz
00:42:03.421: Physical Cores: 2, Logical Cores: 2
00:42:03.421: Physical Memory: 16330MB Total, 9363MB Free
00:42:03.421: Windows Version: 10.0 Build 19044 (release: 2009; revision: 1466; 64-bit)
00:42:03.421: Running as administrator: true
00:42:03.421: Aero is Enabled (Aero is always on for windows 8 and above)
00:42:03.421: Windows 10 Gaming Features:
00:42:03.421: Game DVR: On
00:42:03.428: Sec. Software Status:
00:42:03.457: Microsoft Defender Antivirus: enabled (AV)
00:42:03.487: Windows Firewall: enabled (FW)
00:42:03.515: Current Date/Time: 2022-01-19, 00:42:03
00:42:03.515: Browser Hardware Acceleration: true
00:42:03.515: Portable mode: false
00:42:04.803: OBS 27.1.3 (64-bit, windows)
00:42:04.804: ---------------------------------
00:42:04.808: ---------------------------------
00:42:04.808: audio settings reset:
00:42:04.808: samples per sec: 48000
00:42:04.808: speakers: 2
00:42:04.811: ---------------------------------
00:42:04.811: Initializing D3D11...
00:42:04.811: Available Video Adapters:
00:42:04.823: Adapter 0: AMD Radeon Pro WX 3200 Series
00:42:04.823: Dedicated VRAM: 4274376704
00:42:04.823: Shared VRAM: 4266762240
00:42:04.823: PCI ID: 1002:6981
00:42:04.824: Driver Version: 30.0.14011.3017
00:42:04.824: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=59, name=K242HYL
00:42:04.825: output 1: pos={1920, 0}, size={2560, 1440}, attached=true, refresh=60, name=Artist 24 Pro
00:42:04.872: Loading up D3D11 on adapter AMD Radeon Pro WX 3200 Series (0)
00:42:05.612: D3D11 loaded successfully, feature level used: b000
00:42:05.612: DXGI increase maximum frame latency success
00:42:05.613: D3D11 GPU priority setup success
00:42:08.314: ---------------------------------
00:42:08.314: video settings reset:
00:42:08.314: base resolution: 1920x1080
00:42:08.314: output resolution: 1280x720
00:42:08.314: downscale filter: Bicubic
00:42:08.314: fps: 60/1
00:42:08.314: format: NV12
00:42:08.314: YUV mode: 709/Partial
00:42:08.314: NV12 texture support enabled
00:42:08.323: Audio monitoring device:
00:42:08.323: name: Default
00:42:08.323: id: default
00:42:08.324: ---------------------------------
00:42:08.325: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
00:42:08.337: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
00:42:08.338: Failed to load 'en-US' text for module: 'decklink-captions.dll'
00:42:08.342: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
00:42:11.377: [AMF] Version 2.7.0 loaded (Compiled: 1.4.14.0, Runtime: 1.4.23.0, Library: 1;4;23;0;21.40.11.02;202111261520;CL#2382335).
00:42:12.313: [AMF] <Id: 1> Unable to set converter transfer characteristic, error AMF_NOT_FOUND (code 11)
00:42:13.600: [AMF] <Id: 2> Unable to set converter transfer characteristic, error AMF_NOT_FOUND (code 11)
00:42:13.684: [AMF] [Capability Manager] Testing Direct3D 11 Adapter 'AMD Radeon Pro WX 3200 Series (VEN_1002/DEV_6981/SUB_b0d1002/REV_0010)':
00:42:13.684: H264/AVC: Supported
00:42:13.684: H265/HEVC: Supported
00:42:13.684:
00:42:13.716: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
00:42:13.749: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
00:42:13.751: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
00:42:13.771: [obs-browser]: Version 2.16.3
00:42:13.771: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
00:42:13.786: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
00:42:16.621: Couldn't find VLC installation, VLC video source disabled
00:42:16.745: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
00:42:16.756: No blackmagic support
00:42:16.774: ---------------------------------
00:42:16.774: Loaded Modules:
00:42:16.774: win-wasapi.dll
00:42:16.774: win-mf.dll
00:42:16.774: win-dshow.dll
00:42:16.774: win-decklink.dll
00:42:16.774: win-capture.dll
00:42:16.776: vlc-video.dll
00:42:16.776: text-freetype2.dll
00:42:16.776: rtmp-services.dll
00:42:16.776: obs-x264.dll
00:42:16.776: obs-vst.dll
00:42:16.776: obs-transitions.dll
00:42:16.776: obs-text.dll
00:42:16.776: obs-qsv11.dll
00:42:16.776: obs-outputs.dll
00:42:16.776: obs-filters.dll
00:42:16.776: obs-ffmpeg.dll
00:42:16.776: obs-browser.dll
00:42:16.776: image-source.dll
00:42:16.776: frontend-tools.dll
00:42:16.776: enc-amf.dll
00:42:16.776: decklink-ouput-ui.dll
00:42:16.776: decklink-captions.dll
00:42:16.776: coreaudio-encoder.dll
00:42:16.776: ---------------------------------
00:42:16.777: ==== Startup complete ===============================================
00:42:16.822: Switched to Preview/Program mode
00:42:16.822: ------------------------------------------------
00:42:16.839: All scene data cleared
00:42:16.839: ------------------------------------------------
00:42:17.438: WASAPI: Device 'Speakers (2- High Definition Audio Device)' [48000 Hz] initialized
00:42:17.438: [Loaded global audio device]: 'Desktop Audio'
00:42:17.504: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
00:42:17.504:
00:42:17.925: WASAPI: Device 'Microphone (Blue Snowball )' [48000 Hz] initialized
00:42:17.925: [noise suppress: 'Noise Suppression'] NVAFX redist is not installed.
00:42:17.931: [Loaded global audio device]: 'Mic/Aux'
00:42:17.931: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
00:42:17.931: - filter: 'Compressor' (compressor_filter)
00:42:17.931: - filter: 'Noise Gate' (noise_gate_filter)
00:42:18.059: adding 42 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
00:42:18.059:
00:42:20.061: [Media Source 'Media Source']: settings:
00:42:20.061: input:
00:42:20.061: input_format: (null)
00:42:20.061: speed: 100
00:42:20.061: is_looping: no
00:42:20.061: is_linear_alpha: no
00:42:20.061: is_hw_decoding: no
00:42:20.061: is_clear_on_media_end: yes
00:42:20.061: restart_on_activate: yes
00:42:20.061: close_when_inactive: no
00:42:20.077: [duplicator-monitor-capture: 'Display Capture'] update settings:
00:42:20.077: display: 2 (2560x1440)
00:42:20.077: cursor: true
00:42:20.077: method: DXGI
00:42:20.444: [duplicator-monitor-capture: 'Display Capture 2'] update settings:
00:42:20.444: display: 1 (1920x1080)
00:42:20.444: cursor: true
00:42:20.444: method: DXGI
00:42:20.518: Switched to scene 'Soon Screen'
00:42:20.523: ------------------------------------------------
00:42:20.523: Loaded scenes:
00:42:20.523: - scene 'Scene':
00:42:20.523: - source: 'Media Source' (ffmpeg_source)
00:42:20.523: - source: 'Display Capture' (monitor_capture)
00:42:20.523: - source: 'icon' (image_source)
00:42:20.523: - source: 'Twitch Stickers' (browser_source)
00:42:20.523: - source: 'Follower Alert' (browser_source)
00:42:20.523: - scene 'Soon Screen':
00:42:20.524: - source: 'Image' (image_source)
00:42:20.524: - scene 'Monitor 1':
00:42:20.524: - source: 'Display Capture 2' (monitor_capture)
00:42:20.524: ------------------------------------------------
00:42:20.854: adding 85 milliseconds of audio buffering, total audio buffering is now 149 milliseconds (source: Mic/Aux)
00:42:20.854:
00:42:22.304: adding 149 milliseconds of audio buffering, total audio buffering is now 298 milliseconds (source: Mic/Aux)
00:42:22.304:
00:42:58.388: adding 64 milliseconds of audio buffering, total audio buffering is now 362 milliseconds (source: Mic/Aux)
00:42:58.388:
00:43:47.460: [AMF] <Id: 3> Unable to set converter transfer characteristic, error AMF_NOT_FOUND (code 11)
00:43:48.039: [AMF] <Id: 4> Unable to set converter transfer characteristic, error AMF_NOT_FOUND (code 11)
