Want To Learn
Love one of the new Shaders - It rotates the cube. Thanks!
the new noise filter shader really wrecks my system, 5800x3d and 4070ti. But having other effects on screen seem to have the same performance issue.@therealdadbeard what shader exactly with what settings do you get the performance issues?
@therealdadbeard the smart_denoise.shader can be heavy when you set a high sigma values. The BulgePinch.shader works fine for me. You can check the cpu and gpu usage using the Source Profiler plugin:
Releases · exeldro/obs-source-profiler
Contribute to exeldro/obs-source-profiler development by creating an account on GitHub.github.com
Yeah ignore that, it's an AR effect with the move plugin that gives me encoder overload.Yes but that's not what my point is.
I updated and effects which were fine before suddenly wrecked my OBS. But I will have to update again and check what was going on and get a log if that happens again.
- Add support for move filter transition
- Add previous texture options
- Add repeat grid center effect
- Add hard blink shader
For better chroma key:Hi! Excelent plugin! I was looking for the green_spill_remover and other wich I can use for better chroma keying. Do you made someone? I hope. Thank you!!!
Thanks so much for telling me they might be in the wrong folder. I went in search of the right folder and found it. I put them and composite blur in the folder that has working plugins and now hey all work! I know nothing about software, but have learned a few tricks while trying to install things over the years. You ROCK! show package contents - contents - plugins (this folder.) Thanks for all you do!@Want To Learn does the plugin show in the OBS log file?
Fix dynamic vertex shaders for OBS 31.1
