S sisyphus New Member Apr 17, 2025 #1 Hello guys, My OBS is not launching for the first time, if I start it in safe mode it works, please find attached my logs. Thanks you in advance. Attachments 2025-04-17 00-45-30.txt 2025-04-17 00-45-30.txt 11.3 KB · Views: 61
S sisyphus New Member Apr 17, 2025 #2 The logs Analyzer of OBS shows Hardware-Accelerated GPU Scheduler as critical but it shouldn't be the problem...
P prgmitchell Forum Moderator Apr 17, 2025 #3 Safe mode disables plugins from loading so if it only launches in safe mode, you can assume it is a plugin causing your issues.
