OBS losing audio source when switch between scenes
Kristensen
Hi,
I'm using OBS (29.0.2 - last version) and have scenes that share the same audio source (the same aplication, e.g. Spotify and Discord), but to make OBS capture the audio source I have to restart the aplication/OBS a couple of times and when I change the scene OBS rarely keep tracking the audio input.
I've tried different audio input sources, but now I'm using Aplication Audio Capture (BETA) with the 3º priority option.
There is some option or some way to make this work?
I thought about it... and remembered that the webcam I had to create a scene with only it and add a scene source in others scenes to make it work, so I applied the same method and worked. I'll leave the post open cause maybe have other better way or in the case someone had the same problem.
