No Desktop Audio in Recording
Olli99991_
When I record, in the Sound-mixer it shows a audio signal. But in the Record I don't hear the desktop Audio.
When you want i can send a screenshot from my settings.
sorry for my bad english:)
Make sure desktop audio is enabled or set to the default in the settings.
There might be problem with the latest windows update. Just try turning on the Windows Sonic for headphones. Search for Change System Sound, open the first one, Playback tab, right click on headphone and tap on properties, then to Spatial sound tab and make sure Windows Sonic for Headphones is selected. Do check the screenshot. That's it, check if sound is recorded.
i tried that but it seems that output was set to 48 khz and mic was recording in 44.1 khz. once that was matched, output worked like a charm.
PS: I did the Windows Sonic thingy as well, but not sure if that also helped once I matched the input and output.
