Move
Move 3.1.5
CrasherHS
Maybe someone can help me: For any reason the move transition does not work for me when using Groups.
I have two Scenes both containing a NS as Source called "Webcam [NS]" when I enable the move transition this does work without any issues!
No when i add the Source "Webcam [NS]" to a Group in both scenes "Group" in Scene 1 and "Group 2" in Scene 2 the transition changes completly, since it's not reconized as matching item.
In the settings of the move transition I enable all checkboxes in the "Match if the source name" section.
Anyone knows whats going on here?
CrasherHS
@Exeldro thanks a lot for the fast reply, well that's very weird, I just created a new blank Scene Collection -> Created 2 scenes -> added and Image to each -> Move Transition working -> put each Image into an Group -> Move Transition no longer working.
Scene Collection Download: https://we.tl/t-cYqtsEy3cD
OBS Log: https://obsproject.com/logs/yLSk0VMGeATqC-HR
Quick Demo: https://streamable.com/vyt5k1
So as the scene is right no with the "Image" in the group it is not working for me - if you remove the Image from the groups it is working. Hope you have an idea whats going on here :)
If you need anything else, please let me know.
Exeldro
@CrasherHS when a source is in a group there are 2 ways to resize a source, resizing the source in the group or resizing the group.
You resized the sources inside the group and the move transition only animated the resize of the group itself. That is why you see a sudden change halfway through the transition, switching from 1 group to the other.
You can fix it in multiple ways:
  • using a bounding box transform for your groups (right click-> transform -> edit transform -> bounding box type)
  • using the same group on both scenes (add -> group -> existing)
  • resize the group instead of the source (you can use ctrl+r to reset the transform of the source)
Enma
Hello, I absolutely love this plugin! But I was wondering if it would be possible to have a way to make the Move Source and Move Value filters reverse when turning the filter off. I know you can set it to reverse automatically after finishing the move, but it'd be incredibly useful to have it be able to also reverse when disabled.
Enma
Once again running into crashes when I try to remove these filters from sources (or try to move them up or down the chain). This time the move-value filter, so I'm stuck with filters I don't really want to use anymore. Here's the last crash log
It also just crashes whenever I try to delete or move other filters on the same source after adding the filters from this plugin.
chucho_diaz
Hi! This plugin is the best!
I'm having s small issue where whenever I have my webcam in 2 scenes. In "scene1" my "webcam1" is full scale with default settings. In "scene2" I have "webcam2" (which is a source mirror) with a mask filter where I cut off the sides of the webcam so it doesn't look as wide as with default settings. I do this using "Source Mirror" so I can add different filters to the same source without it affecting the original one. Is there a step I may be missing maybe?
Thank you for all you do for the streaming community man!
That new transition table is a life changer!
Cheers!
chucho_diaz
Cheers!
Oh yeah, I didn't mention that it doesn't animate this source.
Apologies.
Exeldro
@chucho_diaz check all the matching options and rename "webcam1" to "webcam 1" and "webcam2" to "webcam 2"
If that does not work can you send me your scene collection or OBS log file?
cinegamerz
Hey I am having problems, I am using the latest version of OBS and the pluggin, trying to get my webcam to be able to move to different parts of the screen, but the enable and disable trigger is missing? Ive seen a few people mention this, but i cant find a solution. love your pluggins, thans of all the hard work.
kutibotond
Hi, I have a suggestion to list filters from different scenes to "simultaneous move" and "next move" for the following reason. I use multiple scene mirrors for layering my final output. It would make things simpler if it would be possible to activate two movement filers in the same time, despite the filters being on different scenes.
tony_unorthodox
i am having a lot of trouble with this plug in. aside from the movements never going where they are supposed to, i dont have the same settings as ive seen in several youtube tutorials. i can get it to work sometimes but most of the time the image flies off in some undeterminable direction.
these are the settings i get when i try to edit a transition. it only works in 1 uneditable direction:
here is a screenshot of a youtuber who i followed meticulously in order to recreate his transitions:
any ideas?
