Max Audio Buffering
Tallicia
I'm encountering this "error" on a squawk plugin, but not having any actual symptoms that I can detect so far.
moodboosted
This was my log file:
It specifically fixed only the application audio device, as the windows 24h2 update fixes the application audio device from buffering. If your audio is not distorting during the audio buffering then it is not something to worry about.
here is a link to more details about it:
Your audio buffering issue may be different, I recommend going on the OBS discord and sending them a link to your log file
Tallicia
I used the log analysis and no longer have the log entry notification/warning or any issues listed as critical.
