Maidsuit: Draw
Maidsuit: Draw 1.2.1
hi maidsuit
just want to ask if theirs a zip file for your plug-in ? at the moment im currently using a portable version of obs
thanks
There is currently no zip file- but I can provide one for the next upcoming update tomorrow early if you DM me on discord!
maidsuit updated Maidsuit: Draw with a new update entry:
Color Picker, Selection Tools, and Saving Layers
View the update trailer video here:
  • Color picker now added! Find it under the color selection area.
  • Shift press the color picker, or right click the color picker to select the "Pick Directly" color picker, accounts for screen preview and what youre actually visually seeing.
  • Box select, Lasso Select, and Circle select has now been added
  • Select multiple layers with Shift or Control select
  • Save selected layers as flattened PNG &...
I have no idea how I'd even report this, but my first day using this plugin, it crashed OBS one of the times I invoked it, a few seconds after I brought up the drawing panel and clicked the button to show a preview of the current scene (so I can more easily see where I'm drawing). I probably pulled it up at least 6 times during the stream, and that only happened like 4th time. Is there a log kept somewhere I might be able to share to help get to the bottom of what caused this?
