Live Background Removal Lite
Live Background Removal Lite 2.3.1
umireon
umireon updated Live Background Removal Lite with a new update entry:
2.2.1
️ Live Background Removal Lite 2.2.1​
This release adds a handy new tool for plugin maintainers and advanced users!
What's New​
  • Maintenance Script for NCNN Models:
    • A brand new script has been added to help you manage, update, and maintain the NCNN AI models used for segmentation.
    • This makes it easier to keep your models up-to-date, switch between different versions, or perform advanced troubleshooting.
    • Perfect for...
umireon
2.3.0 - Native GPU support on Mac
Live Background Removal Lite v2.3.0 — Now with Native macOS CoreML Support!​
This release is a big step forward for Mac users and plugin developers. Say hello to native Apple CoreML support for lightning-fast, energy-efficient background removal!
What's New​
  • Native CoreML Segmentation on macOS:
    • The plugin now automatically uses Apple’s CoreML framework for background segmentation when running on macOS 12 or newer...
umireon
2.3.1
️ Live Background Removal Lite v2.3.1​
This is a maintenance update with several behind-the-scenes improvements for stability and developer experience!
What’s Improved​
  • Build & Testing Tweaks:
    • Improvements to the build scripts and test infrastructure for easier development and more reliable CI on all platforms.
    • Smoother integration with the CoreML backend for macOS, ensuring tests and builds run as expected.
