Resource icon
jrDockie (save and load window and dock layouts) 1.5
I've uploaded a new version built for obs32 on my main website: http://www.donationcoder.com/Software/Mouser/obs/jrDockie.zip
I've tested it on my new clean OBS 32.0 and it seems to be working fine. Just copy the dll into your obs-plugins\64bit\ directory as usual.
Note that this version will likely not run properly in older versions of obs.
If I can get confirmation that it seems to work without issue I'll upload it as an official new release here.
Seems to be working for me as well! Thank you so much!
I was so happy to see, that there is finally a new build.
It works fine on my end. :D
Works great, even on OBS 31.1.2! It fixed the crashing for me when trying to save the current dock set. Thanks!
EVERY ONE THAT SAY ITS WORKS PLEASE SHOW THE PROOF PLEASE !!
Theirs no Folders called OBS-Pluigins or 64bit in the new version even i created this folders and still dosnt work
the install guild needs to be updated from this
INSTALLATION:
This plugin has been compiled for WINDOWS 64bit
Install plugin as typical by putting the jrdockie.dll file into your obs-plugins/64bit folder.
INSTRUCTIONS:
When you run OBS you should have a new menu under the Docks/ main toolbar called "Dock Sets"
(if that top level menu cannot be found you will see a new top-level menu in your toolbar called "Dock Sets").
You can access the options dialog from that menu or from the Tools/JrDockie menu.
To use, simply choose to SAVE your current dockset into a file, or LOAD an existing one you have previously saved.
The menu will automatically detect dockset files and show them on the recently used bottom areas of the menu, so you should save your dockset files in the recommended location for the plugin.
To manually cleanup (delete, rename, etc.) the dockset files, use the menu option to open the folder directory.
INSTALLATION:
INSTRUCTIONS:
you are using the old EXE installer,
INSTALLATION:
INSTRUCTIONS:
this is the last one before the 1.5 mate
Also their need to be an update on the readme file too and still dosnt work
it says that
INSTALLATION in OBS v32 or later:
For a default obs install this will be something like C:\Program Files\obst-studio\obs-plugins\64bit
the setting folder for windwos 11 64bit is the following
C:\Users\YOURUSERNAME\AppData\Roaming\obs-studio
change "YOURUSERNAME" to your system username
i have to say that im sorry for the last couple of post ive made, so damm confused why it wasnt working. Windows wasn't allowing me to go to the folder that you guys where saying that it was correct, was under read only for some reason but since ive found this out Ive made the folder accessible to obs reinstall this plugin now it works
thanks for pointing this stuff out guys
no worries!
I don't believe my happiness. Finally, I found my precious! This is most of most of most plugin from other plugins, which urgently needed for streamers! I suppose, this is functionality MUST be from the box on OBS. This is obviously on 108%. But why only me?
I'm on OBS 32.0.2
I tried v1.5 several times, maybe like 4 times, and 1.3 accidentally 1 time. I tried using Streamup pluging installer. The file i'm extracting to is my obs-studios/plug-ins/64 file [ obs-studio\obs-plugins\64bit ]. Reset my obs and no docks set. Idk what I'm doing wrong.
it sounds like you are putting it in the right place.
Some questions:
1) So in the directory obs-studio\obs-plugins\64bit you see lots of other (built-in) plugin dlls right? that will confirm you put it in the right place.
2) You are using WINDOWS build (not linux or mac, since this only works on windows)
3) When you run OBS, do you see a new Docks menu?
Some questions:
So I did it wrong, and you found where my brain was messing me up lol, I extracted the whole thing into the file not just the jrdockie file. It works! I cant wait to set it up!
