I will pay you if you fix my microstutters when recording, not in game.
rockbottom
Even with the driver, if the headset is still in play, you're more than likely gonna see lag. It really needs to be removed from the audio chain. That chain will be shorter/faster.
Avduga
I never get any audio lag, not even 21ms & I'll run 6+ hour recordings with many sources.
I have removed my audio hardware and tested.
I will upload my log after my dinner.
Forza Motorsport preview was buttersmooth for the first 5 mins. Then stutter started again.
Avduga
hmm i just noticed that i can attach my log in the message so here we go
  • 2023-12-02 18-10-17.txt
Avduga
In the past it ran good on W10, so i am just going to do a clean install of W10, nvidia driver and OBS.
When i did that, and tested some, i will report again back here.
rockbottom
That Beta BIOS adds support for W11, but going back to W10 is the wiser choice IMO. Good move!
The log is clean, audio lag is good & no lagged frames.
When you're back up & running you should be able to enable "Use Device Timestamps" to the Nvidia Audio capture.
18:10:17.955: [win-wasapi: 'Audio (nvidia)'] update settings:
18:10:17.955: device id: {0.0.0.00000000}.{c2572a5a-9807-4e9f-90cd-78fed4dc13f2}
18:10:17.955: use device timing: 0
rockbottom
Also try running as OBS Admin if any stuttering remains. I don't need to so I don't normally recommend doing so but there is a significant performance boost when it is enabled.
Avduga
Will do @rockbottom ! W10 is installed & activated, installing OBS 2.7.1.3 right now.
I have read that in some cases going back to this version resolves stutters and stuff.
I will let know more once i know more, maybe not tonight but surely very soon.
Avduga
Now installing PUBG, and ForzaMotorsport. These were giving the most issues.
Already set my Nvidia settings just like yours and used CRU to match all refresh rates to exactly 60Hz.
I am not going to connect my headset and mic before i ran my first test.
I also disabled GPU Hardware Acceleration wich from i understand, is also causing issues in OBS.
Avduga
Also disabled GameBar btw
Avduga
OK, finally been able to test.
All 60hz/fps, no sound source added in OBS, same Nvidia settings as @rockbottom , Game:ForzaMotorsport.
Recording 720p60, 10 minutes.
The first 5 minutes were extremely smooth, exactly how everyone would like to see it.
After 5 min the stutter sneaked in and started building up in 1,5 mins.
At almost 7 mins it was back to smoothe again and at 8 a little stutter started.
A little later i added "game capture" instead of "screencapture", this didn't make any difference.
It seems like the stutter comes in at about 5 mins of running OBS, and is "situational".
However i can't hook any moments, events or changes to the timing of the stutter.
  • 2023-12-03 09-57-34.txt
Avduga
Seems like high-end hardware has the same issues.
Avduga
This here also makes a lot of sense.
I am going to figure out multiple fps/hz combinations with CRU and report here.
It HAS to be something like this, right?
Avduga
Fix your rig dude, OBS is not the issue.
I am not saying that OBS is the issue.
I am saying that my refreshrates are out of sync and that's probably the main cause of my problem.
I understand that OBS is not the issue since you helped me eliminating all of the possible issues within OBS.
The issue lies within my own hardware, and i am going got keep trying to solve it since i have come a long way to understand more of OBS.
The reason i keep updating here is to help other people out with the same problem.
The issue is not OBS, but OBS is not working properly due to faulty or poorly adjusted hardware.
People should understand that it's easy to blame OBS, while they haven't eliminated every single possible cause on their PC.
rockbottom
I don't know if it's an accident or if you're just a troll. Starting to think it's the latter. From your last log.
09:57:34.588: CPU Name: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz
09:57:34.588: CPU Speed: 3696MHz
09:57:34.588: Physical Cores: 6, Logical Cores: 6
09:57:34.588: Physical Memory: 16329MB Total, 12517MB Free (NOTE: 32bit programs cannot use more than 3gb)
09:57:34.588: Windows Version: 10.0 Build 19045 (release: 2009; revision: 3693; 64-bit)
09:57:34.588: Running as administrator: false
09:57:34.588: Aero is Enabled (Aero is always on for windows 8 and above)
09:57:34.588: Windows 10 Gaming Features:
09:57:34.588: Game Bar: Off
09:57:34.588: Game DVR: Off
09:57:34.588: Game DVR Background Recording: Off
09:57:34.595: Sec. Software Status:
09:57:34.596: Microsoft Defender Antivirus: enabled (AV)
09:57:34.596: Windows Firewall: enabled (FW)
09:57:34.597: Current Date/Time: 2023-12-03, 09:57:34
09:57:34.597: Browser Hardware Acceleration: true
09:57:34.597: Portable mode: false
09:57:34.774: OBS 27.1.3 (32-bit, windows)
