How to fix your lagged video quality (Low End PC's Read This)
OmegaReaper
So I was thinking a few days ago, A lot of my pals were talking about how buggy and low end the quality of their video was.
And I thought I would just spit out the best settings for OBS.
1. Make sure your encoder is QuickSync. My god, what are you thinking to do without this? Just turn it on, It will change the amount of CPU your computer will have to use. Also, It helps out with streaming also.
2. You should ideally use ICQ and set a quality setting for what looks good to you (the lower the value, the higher the quality).
3. Your max bitrate should be at around 40000 and your minimum at 30000. It helps with my setup a lot and I believe it will help yours also.
4. Also, change you IQP to what you think suits you.
I will leave an
Attachment for anyone to look at incase you are still having troubles with this.
If anyone thinks the max and minimum bitrate is not too high or should be a lot lower, use max as 4000 and minimum as 3000
