Display Fightstick Motions
Free Display Fightstick Motions 210124
MigeruSan
Is possible to make this work/show on my streaming PC to connect to OBS?
I have a dual PC (Gaming PC & Stream PC) .
I know it can work fine with Bluetooth connected to the gaming pc and controller connected to The stream PC but it creates an input delay while playing, delays are not great on fighting games.
iamsneakysnakey
Anyway I can get Fightstick Motion to show keyboard inputs? May sound weird, but I really want to use the tekken input scroll overlay with keyboard.
Samurai233
hi,how should I solve this problem? The displayed command appears to have a gap in the middle, and a button that is pressed only once is displayed twice.
The one on the left is the command displayed in the game, and the one on the right is the command displayed by the plugin.
Thanks!
jbfighter
Hi, Firefox keeps saving my "layout.sav" as a CSS file. I can still open this to get the layout back, but when I do this, the OBS URL only shows the default.
Here, if I click "open in new window" I only get the default:
How do I get this to work properly?
Is this because I can't save a .SAV file? Is there some other way to do it?
RIKEWESKER
boa tarde! O meu arcade funciona normal,porem nada hora que abro o plugin no tela (PRESS ANY BUTTON) nao aparece nada, ja troquei o navegador tanto firefox quanto google ,e não funciona pode me ajudar a desesperadamente.
FilthGnasty
Bumping this. I've looked through the instructions and have searched the thread with keywords and have not found a way to change the stick color. Anyone have any tips?
Just to add more context to this (because I still haven't figured out how to change the ball top color), here is how I have my customlayout folder setup (it doesn't have all the files yet, I know)
And here's how I have the fightstick settings on the webpage. I noticed that there are options to upload images of your button colors when they're pressed and unpressed, but no option for the ball top? Is this intended?
The.Probotector
Hello, I already knew how to change the color of the stick ball, simply replace the "stick-center" photo that is in the "preset" folder and the "stick-up" photo, then the new color will appear by default, greetings
The.Probotector
To be able to edit the color of the buttons exactly (button by button), open the layout.sav file in a text editor and place the name of the photo of the buttons we want, just as it is shown in the photo! greetings <3
sailormoonjira
hello im trying to set up OBS Display for Haute42 R16. But i couldnt make the L/R/Up/Down button work. And where can i find buttons of different colors please?
crisisjack
OBS straight up won't display my inputs for my MixBox. evwrytime I use browser source, it refuses to display any input coming from my MixBox, EVEN IN GAMEPAD VIEWER. This is absurd and I don't know how to fix it. No one seems to have an answer everywhere I go. Help would be greatly appreciated
crisisjack
Update: It does recognize my MixBox but wont display inputs when I click off of the OBS window. I've tried everything that I could find on Youtube or elsewhere. does anyone have a solution? thank you in advance.
MelissaMeantIt
I'm having the exact same issue. Browser source is working correctly, and when opening the web page in Firefox directly it'll work when unfocused. However I need to be focusing OBS for the inputs to register via the browser source. Currently looking for a workaround / fix. In the meantime, maybe opening it up in a separate browser page, using a green background + chroma key could work? But ideally would like to have the browser source functioning first.
Seluecos
Same issue for me. If I click off of OBS, or my browser when configuring/testing, inputs no longer are recognized.
I even tried @MelissaMeantIt suggestion of running as a separate browser page and cropping it down, but as soon as I click off the browser my inputs are no longer recognized.
I'm seeing other streamers and content creators who are using this plugin actively and without issue, but no matter what I try, I can't get the inputs to display if OBS is not the active window. It's impossible to play games and have my inputs display.
Any help is appreciated!
xxdocobxx
Update: It does recognize my MixBox but wont display inputs when I click off of the OBS window.......
I'm having the exact same issue. Browser source is working correctly, and when opening the web page in Firefox directly it'll work when unfocused......
Same issue for me. If I click off of OBS, or my browser when configuring/testing, inputs no longer are recognized......
The Browser Source has been updated in the new version of OBS, which is causing this problem.
One workaround is to use an older version of OBS (I guess version 30.2.3 should be fine).
Another workaround is to add "--disable-features=EnableWindowsGamingInputDataFetcher" to the OBS shortcut like:
"C:\Program Files\obs-studio\bin\64bit\obs64.exe" --disable-features=EnableWindowsGamingInputDataFetcher
(Note that you need to add a space character before "--disable-features..." and also change the file path to yours.)
