Better Screenshot Plugin
Better Screenshot Plugin 1.2.2
MMLTech
MMLTech submitted a new resource:
Better Screenshot Plugin - Better Screenshot a simple plugin that makes taking and sharing screenshots way easier.
Better Screenshot for OBS Studio is a simple plugin that makes taking and sharing screenshots way easier.
Instead of saving huge PNG files like OBS normally does, it lets you use JPG or WebP to keep file sizes much smaller without losing noticeable quality.
You can:
  • Take screenshots with a custom hotkey
  • Choose the format and quality
  • Save them to a specific folder
  • Automatically send...
MMLTech updated Better Screenshot Plugin with a new update entry:
Hotfixes
  • Rapid screenshots are now serialized, preventing re-entrant captures from overwriting shared screenshot state.
  • Original OBS images are deleted asynchronously after a short delay, with up to eight retries.
  • Cleanup failures are logged instead of showing misleading errors after the converted screenshot was already saved.
  • Qt TLS plugin paths are configured only when a valid HTTPS Discord webhook is actually used.
  • Missing qschannelbackend.dll no longer affects packaging or...
