WayZHC said:With that upload speed you have to downscale to 480p or even 360p and use bitrate 550 or 550 (use CBR) and maybe 64Kbps AAC audio. And fps to about 25. Your upload speed limits you a lot. So 720p would be blurry as hell.
Your hw would be able to stream SC2 at even 720p 60 fps but your connection limits A LOT.
Try OBS Estimator https://obsproject.com/estimator
(E: just to make sure 0.87Mb is 870Kbps and estimator asks it in Kbps)
alpinlol said:since you oc'ed your i5 quite a lot you could try 650 bitrate/buffer 720p@25 with faster preset and see how your cpu usage gets up
Actually, chose a server in OBS that is close to you as well. ;)WayZHC said:Actually choose a server near the server you are willing to stream at.
I know since Frankfurt server sucks ;) I use Amsterdam server. But lets get back to the topic and help the OP.Kharay said:In your case I would actually suggest Amsterdam. Because, of... well... http://en.wikipedia.org/wiki/Amsterdam_ ... t_Exchange
Just capture the game in its native resolution and use the downscale function (using the Lanczos filter) to scale it down to 720p. What resolution do you play it at?Kharay said:I'm sure you could get away with CBR 1500 Kbps in 720p @ 60 FPS, actually. Try it and see what happens.
Just leave those settings at default. So, veryfast. Serves SC2 just fine.Mackem said:Do I choose veryfast, faster, fast etc.?
