Battlefield 1 and Battlefield 6 OBS Issues
westk
Hi there, I don´t know when started these issues but could be the last year. I can´t stream only these two games because the Frames missed due rendering lag and also skipped frames due encoding lag. I mean, I can reproduce this issue without even streaming. If I open any of these two games and I move the mouse, I can see the lag only in OBS. The game runs perfectly fine. The CPU and GPU are totally relaxed. Battlefield 1 is a really old game and I play it at 180 FPS, but in OBS lags even in the game menu.
The funny part is this happen only with just these two games. I tested every option around. Downgrading OBS version to 32.0.2 (this version just can´t capture the game even) Touching everything in the game capture, anti cheat compatibility, etc. Turning off HAGS. OBS Safe Mode.
Please help me, thanks
1. In Windows, we recommend that "Game Mode" be enabled. Game Mode can be enabled via the Windows "Settings" app, under Gaming > Game Mode.
2. Multiple Game Capture sources are usually not needed, and can sometimes interfere with each other (all your scenes). You can use the same Game Capture for all your games. If you change games often, try out the hotkey mode, which lets you press a key to select your active game. If you play games in fullscreen, use 'Capture any fullscreen application' mode.
Is OBS running on your 1080p monitor?
I have game mode uninstalled and always was in that way. Last year both games worked fine. OBS is in the second monitor (FHD)
Finally I´ve found the solution. The issue was always OBS. There was a lot of sources enabled and created. I just started turn them off (not even deleting them) and this resolved the rendering lag (and I assume the encoding lag too).
