royshilkrot
i haven't done it but basically you would use the .zip version and put the plugin files in the portable OBS folderExcellent plugin, but how do I install this in portabel mode, tried everything and can't get it working
Thank you for the kind words @Want To Learn ! I'm glad to hear this has helped youHi Roy,
I had been with you from the start. Learned a little bit about how to install software into OBS without an installer 2 or 3 yrs. ago etc.... I downloaded every upgrade, which eventually came with a traditional .dmg installer for the mac. Fast forward to today. For my purposes it's working great! It's for one on one lessons on-line. Now, I don't need to set up a physical green screen in the tight space that I live in, which can be a pain sometimes. I also don't want people to see a big mess either. LOL. THANK YOU SO MUCH!
I'm a Mac guy, but I would first make sure that you double check that you downloaded the specific to your PC and operating system and that you have the correct OS and version of OBS. Good luck!I downloaded and installed the plugin (Windows 10) but "background removal" isn't showing up in my list of filters. Did I miss a step?
royshilkrot submitted a new resource:
Background Removal - Portrait Segmentation - Remove the background in your camera video with the power of neural networks.
Thanks Wesley, I'm new to Linux. How do I manually verify? Where is the correct obs plugins directory in Linux Mint, what files are supposed to be there, and, if they aren't, what next?you need to manually verify that the plugin files were actually placed in the correct obs-plugins directory.
Sean I installed the same plug in on my Windows machine last week, I got the same message. I don't recall exactly, but I think all I did was restart my computer, and then obs started up normally and the background remover was there and working just fine. Hope this helps, because beyond that I have no idea...I haven't been so lucky getting the plugin installed on my Linux...I installed OBS-Studio-31.1.1-Windows-x64-Installer.exe and obs-backgroundremoval-1.1.13-windows-x64-Installer.exe.
After installing the plugin, OBS does not start properly. The message is 'OBS did not close down well, start in safe or normal mode.' I had to uninstall the OBS plugin to get OBS working again. Do you have a fix?
