Audio/Mic Issue
OBS detects my microphone perfectly fine, but won't take any audio from it at all. I've restarted it, reinstalled it, checked all my audio tracks, checked windows usage settings, and modified any other audio settings related to similar issues I've found on here. Nothing works. If anyone has had a similar issue or the same issue then your help would be greatly appreciated.
A log file is needed. Look at the pinned posts on how to get it.
Do the mic works on other apps / programs? Do you see the vu meter in OBS move when you speak on the mic? Did you unintentionally muted it?
Yeah, Mic works on Roblox, Discord etc. The meter doesn't move at all when I speak and I've made sure everything isn't muted. Once I get it do you want me to send the log file here?
This isn't my area of expertise, but this doesn't look right
16:18:52.169: Device for 'Audio Output Capture' source Desktop Audio is also used for audio monitoring.
16:18:52.169: Deduplication logic is being applied to all monitored sources.
16:18:52.169: [win-wasapi: 'Desktop Audio'] update settings:
16:18:52.169: device id: default
16:18:52.169: use device timing: 1
16:18:52.170: [Loaded global audio device]: 'Desktop Audio'
16:18:52.171: [win-wasapi: 'Mic/Aux'] update settings:
16:18:52.171: device id: {0.0.1.00000000}.{eaa8e531-b5a4-458e-880b-7d534af4fac7}
16:18:52.171: use device timing: 1
16:18:52.188: Device for 'Audio Output Capture' source Desktop Audio is also used for audio monitoring.
16:18:52.188: Deduplication logic is being applied to all monitored sources.
16:18:52.226: [WASAPISource::TryInitialize]:[External Microphone (Synaptics HD Audio)] Failed to initialize audio client: 8007007E
16:18:52.226: WASAPI: Device '{0.0.1.00000000}.{eaa8e531-b5a4-458e-880b-7d534af4fac7}' failed to start (source: Mic/Aux)
OBS Studio will, assuming you know what you are doing, let you set up a config that often won't work
Capturing Desktop Audio makes sense, BUT then you have to manually (usually physically, like headphones) ensure your don't create an audio loop. Sorry to say, that is 100% on you to understand, and avoid. A mic that gets fed to Desktop Audio that is output on a speaker also captured by mic is an instant loop.
1. I didn't change anything, I don't even modify the hot keys in settings and it only started working weird after new years
2. Factory resetting my pc fixed it anyway
