Resource icon
Hi, will there be any updates to the project? I'm just having a small problem with the GIF animation; it restarts when any text is changed.
I’m already working on the next version, this will drop the use of local webserver and will alao do a couple tweaks to the placeholder sistem but I’m working on my plugins during my spare time so the new update may only be available by next weekend.
But I was referring to the Lower Third 1.6 plugin; I'll test yours here to see if I can adapt to it.
@MMLTech - Thanks for sharing your plugin, Smart Lower Thirds (SLT). I've been using the Animated Lower Thirds (ALT) for years, but considering that ALT is apparently no longer being maintained/updated, I was looking for potential replacements.
There's a feature in ALT that I greatly value that I believe is not yet available in SLT. With ALT I can create a "parent" lower third with multiple, interdependent "child" lower thirds (i.e. "slots"). Along with a timer, that parent lower third will cycle automatically through each child (same position on screen), allowing me to effectively show multiple lower thirds, one-at-a-time in an organized, timely manner. From my understanding of your tool, I cannot currently do that with SLT.
Is my understanding correct? If not, how would I emulate that functionality within SLT? If so, are there plans to incorporate a lookalike feature in SLT?
Thanks in advance for your response!
Hei, well you can do a workaround for that in SLT by creating multiple lower thirds and playing with "Repeat every(sec):" and "Keep visible (sec):" but that sounds like a nice feature to be added in the next versions of SLT to have a "Carousel" automation where you can group multiple lower thirds and cycle them to a given delay. I'll have that noted down on github as a new feature for the future.
Thanks for the prompt reply! I've added SLT to my "watched resources" list, so I'll keep an eye out for future updates and switch over as soon as that "carousel" feature is added. Thanks again!
It’s already planned for the next version, currently under testing
Hi,
Great work ! I have a question : i'd like to have lower thirds to have score alerts. I'm running OBS on linux and access to a windows share where are stored several text files. The score are entered on one of these files. Is it possible to read a text file so the lower-third title or subtitle can be automatically changed without any action on the OBS computer ?
Thanks for your answer ;)
Hi,
You can create a lower third in SLT using and in the javascript template write your own reading logic from that files and wire them to const $ = (sel) => root.querySelector(sel); in other words is doable but requires some codding knowledge, you can try with a AI to help you read from that files
Thank you for your quick answer ! Programming could be a solution, but i don't want to break what's working now, as the first lives will occur in 3 weeks from now (and I have a lot of thing to secure...). I'll try this with the gap between games 2 and 5 (approx 1 month) and tell you what it gave ;)
Again thanks for your job/work ! ;)
Hi again,
Another day, another question... I'd like to have several group of Lower thirds : One, already done, that appears on top left screen. I have no problem with this one.
I want another group, to appear on a second browser (because the first one is full screened, as this one would be only displayed both left and right but mid height of the screen). I want 2 LT to be displayed simultaneously (one left and one right).
This is done like this on my OBS (On the screen capture, only one browser appears, but i have 2 browsers, each one on a separate scene) :
The "Grenoble ATTAQUE" is meant to appear from the left, and "Grizzly Defense" is meant to appear from the right... I don't know if i'm doing things the wrong way, or if there is some kind of limitation.
In order to be complete, Im using Linux OBS/SLT...
Best regards ;)
Hi again,
Best regards ;)
I just realized we are on the wrong thread. This is the thread for Smart Lower Thirds https://obsproject.com/forum/resources/smart-lower-thirds.2275/ and what you asked is doable in the version 2.7.0 using lower thirds groups
Greetings to the developers and the community,
First of all, I would like to thank you for this wonderful plugin. I’m an enthusiastic OBS beginner, and I’ve been using this plugin for quite some time because I truly think it’s excellent.
Unfortunately, after several recent OBS updates, the plugin stopped working due to new security restrictions implemented by OBS itself.
After spending a long time testing different approaches — and almost giving up — thanks to the help of AI, along with persistence and determination, I managed to get it working again. I should mention that I’m not a professional programmer, although I do have some technical background.
I would now like to share the modified version of the project so that it works with the latest versions of OBS. I would greatly appreciate it if you could test it and let me know whether it is useful for you.
Here is the GitHub repository link where you can download the modified file.
Best regards.
Best regards.
Thanks for the update to this! I installed it and it works on my Linux machine. However, when I tried to add an image to the lower thirds, it seems to work the way it is supposed to: I am able to add the image. But, when I close the 'Choose Image" box, I get the following image (see attachment).
Hi DVandy,
Sorry for the delay in responding.
I was able to reproduce the error you mentioned, and it occurs when selecting an image from any location outside the plugin’s folder.
To ensure the plugin works correctly, please verify the following:
  1. Plugin location:
    The plugin folder must be placed inside the OBS installation directory.
    For example, on Windows:
    C:\Program Files\obs-studio\Animated-Lower-Thirds-Fixed
    (I’m not entirely sure what the equivalent structure looks like on Linux).
  2. Image location (most important step):
    Inside the plugin folder, there is a directory called "logos".
    The image you want to use must be stored in that folder, as the plugin can only read files from there.
Please check these steps and let me know if it resolves the issue.
Best regards,
Hi I have the 1.6_V2 installed from here but I cant get it to go blue, the Master controller goes Blue but the individual ones go red when switched on?
Dear akimba,
Please verify that your browser-source.html source is configured as follows:
  1. Make sure “Local file” is unchecked.
  2. If you are using Windows, the URL should look similar to this:
    file:///C:/Program%20Files/obs-studio/Animated-Lower-Thirds-Fixed/lower%20thirds/browser-source.html
This is important because the plugin folder must be located inside your OBS installation directory.
Regards
