Resource icon
Free Animated lower thirds with control panel 2020-04-12
Hello, congrats for this excellent tool but i can´t do work. I add a control panel and a new browser source when i click on show, nothing happen. Please can help me ? Thanks
Its an amazing tool to build lower-thirds.
Appreciate if anyone could enlighten me about how to config the "logo.png" to be shown at the left-bottom corner!! I am not very good at CSS coding.
Thanks for the help. I discovered what´s happend. In OBS Config, in the advanced menu, the option: hardware acceleration for navigator its enabled. Just i disable it and works well.
This is so cool! I have a question. I understand js, css, and html. My question is "how do these two pages talk to each other? Do they share the same javascript 'space' in OBS? Where can I read more how this works?" Thanks!
If you are on Mac, you can add the controller as a new Browser source, then click the "eye" to make it not show. Then right-click it and choose "interact" and you can use the controller that way.
Downloaded this in the morning, up and running in a few minutes. Nice clean code too. Thanks so much, great job!
First, you need to know where you unzipped the file, then navigate to [common\images] this path is where the logo is.
Here you can change the Logo as you see fit.
If you want to config the logo, go to the browser-source.html file and edit, make sure the logo you want is inside the [common\images] folder
@from1975 This is amazing!
I did have two side questions as a non-coder: Is it possible to run 2 of these at the same time? Is it possible to make it generate more than 2 lines of text (lets just say I wanted 4 lines of text).
Hey, you asked 2 questions, I can answer one right now, the other I need more time to play around.
Yes, it is. See the attached screenshot and the steps.
Steps
1: Duplicate Common and lower thirds folders e.g "common2", and "lower thirds2"
2: Open the lower thirds2 folder, open the browser-source.html file in an editing app like Notepad++
2.0 -- Modify the following lines
2.1:- <link rel="stylesheet" href="../common/css/style-001.css"> to <link rel="stylesheet" href="../common2/css/style-001.css">
remember "common2" is the name of the duplicate folder.
2.2:- var bcc = new BroadcastChannel('obs-lower-thirds-channel'); to var bcc = new BroadcastChannel('obs-lower-thirds-channel1');
the reason adding the 1, is to tell the script to use a different name, if you use the same name, it will always populate the 2nd panel. You can add anything to it, just make sure the name is different.
2.3:- <img src="../common/images/logo.png"> to <img src="../common2/images/logo.png">
this is to reference the logo from the proper folder.
3: Open the lower thirds2 folder, open the "control-panel.html" file in an editing app like Notepad++
3.0 -- Modify the following lines
3.1: <link rel="stylesheet" href="../common2/css/style-001.css">
this is to reference the stylesheet from the proper folder.
3.2: <script src="../common2/js/jquery.js"></script>
this is to reference the jquery from the proper folder.
3.3: var bc = new BroadcastChannel('obs-lower-thirds-channel1');
this is to reference the name created earlier in STEP 2.2.
4: Create your docks, add the Browser Source, and have fun.
This is absolutely fantastic. Thanks you so much for the tip. I'm very new to html, and I have a follow-up question. How can I change the colors in the lower third text to a bright white (#FFFFFF). If someone could point me in the right direction, this rookie would greatly appreciate it. Cheers.
Hey, there, luckily for you I just did exactly what you needed.
1) Go to your "common\css" folder
2) open the "style-001.css" file in an editor such as NotePad or NotePad++
3) To change the Name(top text)
scroll down to "body.browser-source.lower-thirds #lower-third #name" then change the color
4) To change the Function(bottom text)
scroll down to "body.browser-source.lower-thirds #lower-third #function" then change the color
5) Save the file and have fun... See the attached screenshot.
Hi,
great tool, very easy to use and apply, very clean, thank you so much!
Can anybody help on how to create an underlying semi-transparent box? I'd like to make the logo and writing stick out independent of the content underneath. Of course i can supply an image, but then I would lose the "show/hide" and animation facility. Any help or ideas are greatly apprecitated, thank you!
Peter
Hello...
Thanks for the great tools in my new OBS interface (lowerthird dock/panel)....
But somehow I need to put a stroke or shadows in a text...
Could someone please tell us on how to put the script...
Thanks..!
Hi,
Peter
Can you provide a sketch of what you need and the image, let me play around it.
Hi,
Peter
Hey Peter, I just played around and came up with this
Basically all i did was,
1) go to the "browser-source.html" file, it will be located in the "Lower thirds" folder
2) Open in a note editor such as NotePad++ or even the default Notepad on Windows.
3) Modify this line from
<div id="lower-third">
to
<div id="lower-third" style="background-color:#d3d3d3;box-sizing: border-box;border-radius: 8px;">
4) Save the file and cheers.
Explanation of the code added:
Background-Color: light grey
border-radius: make the border a bit like a circle, not a perfect square.
N.B: Remember to reload/rrefresh the BROWSER SOURCE in OBS to apply the changes.
Pro-Tip: Download "refresh-browsers.lua" file to help reset all browser sources Globally.
I modified my file, to add a CLEAR button, this will clear all the text from Program/Preview and the Control-Panel textbox in OBS.
Is there a way to make an image appear instead of the text? I have full screen images that already exist and want to use them. I have removed the logo and replaced the names with the name I will use but would like to use an image instead of the names.
Thank you in advance.
