Aitum Vertical
Aitum Vertical 1.6.4
I love this product. It makes dual streaming on twitch and tiktok a breeze. One issue though...Are there any plans to add a stream delay feature? Currently, you can apply a delay to the horizontal stream but not the vertical stream. Thanks!
I don't know if this has been asked or answered, but was wondering how much of a resource increase the vertical plugin uses when streaming on it. I have everything in the vertical plugin settings set to match main OBS. I'm also streaming on a single PC setup. Haven't started using it yet but wanting to make sure I don't cause any hiccups in quality or dropped FPS when multistreaming.
Is there a way to switch which canvas the virtual camera uses? I have run into a use case where I need to use my main 16:9 canvas as a virtual camera but there's no option to switch and Aitum seems to hijack the virtual camera. For the cases where I need my main canvas to output to the virtual camera; I'd like there to be an option. Right now the only thing I could think of, is changing the settings in the vertical plugin to be a 16:9 resolution but that defeats the purpose of it solely being for a vertical aspect ratio.
Aitum updated Aitum Vertical with a new update entry:
Version 1.4.0
  • Added virtual camera mode (Vertical/Main/Both)
  • Added Downstream Keyer support
  • Added ability to add stream delay
  • Added blend mode to scene item context menu
  • Added scale filter to scene item context menu
  • Added show in multiview to scene context menu
  • Fixed some memory leaks
  • Fixed crashing on closing
  • Fixed locked and visibility icons for OBS 30.1
  • Fixed debug logging in OBS 30.1
This plugin doesn't work for me, except when I first install it. Then, when I close OBS, I get a crash report each and every time. When I reopen OBS, I need to manually load the vertical docks again. And, quite often, my source docks are bugged and I'm unable to click the plus sign to add new sources, or right click. The only solution I've found is to delete the plugin config folder, which makes it a fresh install again, but having to do that every time is just not practical.
I'm putting in my crash report just in case anyone can see something I don't.
OBS 30.0.2 log file uploaded at 2024-02-19, 15:35:59
15:34:37.889: [macOS] Permission for audio device access granted.
15:34:37.891: [macOS] Permission for video device access granted.
15:34:37.893: [macOS] Permission for accessibility granted.
15:34:37.897: [macOS] Permission for screen capture granted.
15:34:37.897: CPU Name: Apple M3 Pro
15:34:37.897: Physical Cores: 11, Logical Cores: 11
15:34:37.897: Physical Memory: 36864MB Total
15:34:37.897: OS Name: macOS
15:34:37.897: OS Version: Version 14.3 (Build 23D56)
15:34:37.897: Rosetta translation used: false
15:34:37.897: Kernel Version: 23.3.0
15:34:37.898: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
15:34:37.898: Current Date/Time: 2024-02-19, 15:34:37
15:34:37.898: Browser Hardware Acceleration: true
15:34:37.898: Qt Version: 6.5.3 (runtime), 6.5.3 (compiled)
15:34:37.898: Portable mode: false
15:34:37.969: OBS 30.0.2 (mac)
15:34:37.969: ---------------------------------
15:34:37.969: audio settings reset:
15:34:37.969: samples per sec: 48000
15:34:37.969: speakers: 2
15:34:37.969: max buffering: 960 milliseconds
15:34:37.969: buffering type: dynamically increasing
15:34:37.970: Initializing OpenGL...
15:34:37.996: Loading up OpenGL on adapter Apple Apple M3 Pro
15:34:37.996: OpenGL loaded successfully, version 4.1 Metal - 88, shading language 4.10
15:34:38.132: ---------------------------------
15:34:38.132: video settings reset:
15:34:38.132: base resolution: 1080x1920
15:34:38.132: output resolution: 1080x1920
15:34:38.132: downscale filter: Bicubic
15:34:38.132: fps: 30/1
15:34:38.132: format: NV12
15:34:38.132: YUV mode: Rec. 709/Partial
15:34:38.132: NV12 texture support not available
15:34:38.132: P010 texture support not available
15:34:38.132: Audio monitoring device:
15:34:38.132: name: Default
15:34:38.132: id: default
15:34:38.135: No AJA devices found, skipping loading AJA UI plugin
15:34:38.135: Failed to initialize module 'aja-output-ui'
15:34:38.136: No AJA devices found, skipping loading AJA plugin
15:34:38.136: Failed to initialize module 'aja'
15:34:38.137: Failed to load 'en-US' text for module: 'decklink-captions'
15:34:38.138: Failed to load 'en-US' text for module: 'decklink-output-ui'
15:34:38.138: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
15:34:38.138: Failed to initialize module 'decklink'
15:34:39.263: [obs-browser]: Version 2.22.2
15:34:39.263: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.61.26+g3630089+chromium-103.0.5060.134 (compiled)
15:34:39.272: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.3.4 | RPC Version: 1)
15:34:39.272: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.5.3 | Qt version (run-time): 6.5.3
15:34:39.272: [obs-websocket] [obs_module_load] Linked ASIO Version: 102800
15:34:39.274: [obs-websocket] [obs_module_load] Module loaded.
15:34:39.281: [Vertical Canvas] loaded version 1.4.0
15:34:39.282: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 0x0105): tried: '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file), '/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib' (no such file)
15:34:39.282:
15:34:39.282: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
15:34:39.283: Loading iOS Camera Plugin (version 2.9.6)
15:34:39.284: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
15:34:39.284: [obs-multi-rtmp] Load 1 targets, 0 video configs, 0 audio configs
15:34:39.284: [obs-multi-rtmp] Load config from /Users/user/Library/Application Support/obs-studio/basic/profiles/Untitled/obs-multi-rtmp.json
15:34:39.336: [obs-multi-rtmp] version: 0.5.0.4 by SoraYuki https://github.com/sorayuki/obs-multi-rtmp/
15:34:39.337: ---------------------------------
15:34:39.337: Loaded Modules:
15:34:39.337: obs-multi-rtmp
15:34:39.337: obs-ios-camera-source
15:34:39.337: vlc-video
15:34:39.337: vertical-canvas
15:34:39.337: text-freetype2
15:34:39.337: rtmp-services
15:34:39.337: obs-x264
15:34:39.337: obs-websocket
15:34:39.337: obs-webrtc
15:34:39.337: obs-vst
15:34:39.337: obs-transitions
15:34:39.337: obs-outputs
15:34:39.337: obs-filters
15:34:39.337: obs-ffmpeg
15:34:39.337: obs-browser
15:34:39.337: mac-virtualcam
15:34:39.337: mac-videotoolbox
15:34:39.337: mac-syphon
15:34:39.337: mac-capture
15:34:39.337: mac-avcapture
15:34:39.337: image-source
15:34:39.337: frontend-tools
15:34:39.337: decklink-output-ui
15:34:39.337: decklink-captions
15:34:39.337: coreaudio-encoder
15:34:39.337: [Vertical Canvas] Loaded configuration file
15:34:39.408: QLayout: Attempting to add QLayout "" to CanvasDock "contextContainer", which already has a layout
15:34:39.409: NV12 texture support not available
15:34:39.409: P010 texture support not available
15:34:39.432: [VideoToolbox encoder]: Added VideoToolbox encoders
15:34:39.432: QWidget::setTabOrder: 'first' and 'second' must be in the same window
15:34:39.432: ==== Startup complete ===============================================
15:34:39.485: All scene data cleared
15:34:39.485: ------------------------------------------------
15:34:39.546: coreaudio: Device 'BlackHole 2ch' [44100 Hz] initialized
15:34:39.546: [Loaded global audio device]: 'Desktop Audio'
15:34:39.573: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
15:34:39.573:
15:34:39.583: coreaudio: Device 'MacBook Pro Microphone' [44100 Hz] initialized
15:34:39.583: [Loaded global audio device]: 'Mic/Aux'
15:34:39.662: [obs-ios-camera-plugin] Creating instance of plugin!
15:34:39.662: [obs-ios-camera-plugin] Loaded Settings
15:34:39.665: [obs-ios-camera-plugin] Updated device list
15:34:39.665: [obs-ios-camera-plugin] deviceManagerDidChangeState 2
15:34:39.697: adding 42 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Samsung Monitor)
15:34:39.697:
15:34:39.756: coreaudio: Device 'Shure MV7' [48000 Hz] initialized
15:34:39.756: Switched to scene 'Scene'
15:34:39.757: ------------------------------------------------
15:34:39.757: Loaded scenes:
15:34:39.757: - scene 'Scene':
15:34:39.757: - source: 'iPhone' (ios-camera-source)
15:34:39.757: - source: 'Samsung Monitor' (screen_capture)
15:34:39.757: - source: 'Shure Mic' (coreaudio_input_capture)
15:34:39.757: - scene 'Vertical Scene':
15:34:39.758: [obs-ios-camera-plugin] Activating
15:34:39.914: [mac-virtualcam] macOS Camera Extension activated successfully.
15:34:41.092: ==== Shutting down ==================================================
15:34:41.094: [Vertical Canvas] Saved settings
15:34:41.100: Double destroy just occurred. Something called addref on a source after it was already fully released, I guess.
@keithedwards This crash I seem to get only reported on Mac so far which makes finding the issue a bit harder for me as I don't own a Mac, but we are working on finding the issue and will let you know if we need more information.
I want to setup a hotkey to change vertical scenes on the vertical canvas window only. But instead it was the main canvas window where the scene is changing.
Anyone use overlapping hotkeys like this and figure it out? I use the same 4 scenes between vertical and horizontal, so I'd just like to use the same hotkey to switch scenes — but the vertical scenes end up in the main OBS preview if you do this.
Worst case I use different hotkeys to switch vertical scenes, but I'm having to remember tons of hotkeys already. I really like being able to overlap them in OBS for a lot of functions.
EDIT: Actually, it doesn't matter if they share hotkeys, since scene-switching will always end up in the main preview. So the worst case scenario doesn't work.
Annnd it looks like there's "Linked Scenes" by right-clicking the vertical scenes. Whoops. Very cool. Can't edit that post up there anymore.
