Hi @Exeldro,
I can see that several people have already mentioned they've lost control over their vertical scenes/sources via the obs-websocket since they upgraded to 32.0.0.
I am having the exact same issue where my Tiktok Live stream is entirely dependable on the Aitum Vertical plugin. Having nearly a 1000 vertical sources and nested scenes, I've been displaying various effects through Tikfinity and Streamerbot
Is there any upcoming solution to this and which support should we address to have this resolved? Is there a temporary fix we could apply?
Please advise.
Still nothing here? How are others controlling their vertical sources if they have a stream deck? Did they rollback their OBS version?Hi @Exeldro
I Just wanted to follow up on this. I can see many people have posted about, but I don't see that it has been addressed. I initially thought it was an Elgato issue so I put a support ticket in with them but they were never even aware that Stream Deck supported recognizing our Aitum Vertical Sources so they said it had to be an issue that you guys changed with an Aitum or OBS update. I'm preparing to start streaming again, but have no idea how I will control my vertical sources with my Stream Deck as hotkeys are such a pain to deal with.
posting to follow for an answer. Having the same issue.Still nothing here? How are others controlling their vertical sources if they have a stream deck? Did they rollback their OBS version?
Thank you very much!!!@FabioElizeu that is possible to add, might take some time as I am focusing on other projects at the moment. You can try Aitum Stream Suite instead of Aitum Vertrical which supports that already.
Hi @Exeldro
- Fix saving and restoring scene order
- Fix crash with resolution not divisible by 2
- Fix Audio wrapper not muted
- Fix conflicting with Aitum Stream Suite by preventing loading
I lost the ability to see my Vertical Scene and Vertical Sources docks. this is a big pain. what happened? i've reset the UI and reset the docks and i still dont see them. All i see a dock named AITUM VERTICAL and it has the preview window + scenes in one window -- but i cant edit any scene or sources. help!Aitum updated Aitum Vertical with a new update entry:
Version 1.6.2
- Add scene switch hotkey
- Add logging of vertical scenes
- Fix edit transform for OBS 32.1
- Fix use latest version for new sources
- Add hotkeys for enabling and disabling the preview
- Add update question dialog
- Update support us link
- Fix double switch scene hotkey
