Aitum Multistream
Aitum Multistream 1.0.8
Hi all. I have several instances of OBS-Portable, After first install I cannot proceed with installation of the plugin for other OBS apps. After the first installation, the path for installation is predefined and chosing automatically. Is there a portable version of a plugin by any chance?
First, for portable installations, you want the ZIP file, not the installer. That can be found at Aitum's Github.
--Katt. =^.^=
Hello everyone,
I have a small problem with the tool, maybe you know why it doesn't work.
I have Twitch as my main stream platform and would like to set Mixcloud as the main canvas via Aitum with a different setting to Twitch. I can change everything but when I change the FPS from 60 to 30 it is not saved and I have no idea why.
I have tried different encoders but nothing works :(
If I set the FPS to 30 in the settings of the main platform Twitch, it is taken over again in the main canvas of Aitum. It is therefore currently not possible to change the FPS under Advance Encoding. Which is a pity :(
I tried Multiview to stream Facebook and youtube but my cpu usage pushed 95% when streaming both. Will this plugin give me the same cpu usage.
Interestingly, in OBS I cannot select NVIDIA NVENC AV1 when the Primary YouTube Ingest server is selected to do an HLS stream. I assume that is because one cannot do AV1 over HLS to YouTube in OBS at the moment. I'm okay with that for now. However, this plugin allows me to select what is apparently a non-valid encoder option that does not work, and will not produce a stream on YouTube.
I'd prefer to be able to do AV1 with HLS, but if that is not possible, the plugin should not allow NVIDIA NVENC AV1 to be selected as an encoder option when the Primary YouTube Ingest server is selected. This is the behavior in OBS.
Thanks for all you do.
When I use Twitch as my Primary Stream, and turn on other streams, I have VOD Track set to 6. YouTube Stream audio set to Track 6, and I am still getting music in my YT VoDs which should not appear as music is ONLY set to Track 1. This happends RANDOMLY. Sometimes it works, others it does not.
Adding the websocket part would be so useful to automatically update the stream key and URL of a given stream (a selection by Name or id) Indeed for example for TikTok the key changing with each stream it's tedious to have to manage this addition manually in the same way when starting and stopping the stream (via TikTok live management utilities) the vent allowing to start/stop a specific stream via websocket would really be the top
Hello. I would like to make a suggestion to add a button that starts/stops broadcasts of all added channels.
Or, like in the Multiple RTMP Target plugin, give it the option to be triggered by clicking "Start Streaming" and/or "Stop Streaming" per target.
That way, you only press one button to light up all desired streams at once.
--Katt. =^.^=
Is there any plans for Stream Deck integration? Would be very useful!
Not building on Arch Linux (SteamOS is a derivative of Arch).
Build Error:
CMake Error at cmake/common/helpers_common.cmake:89 (set_property):
  set_property can not be used on an ALIAS target.
Call Stack (most recent call first):
  CMakeLists.txt:29 (find_qt)
I checked git
- main branch
- 1.0.6 tag
- 1.0.5 tag
P.S.: Why disable bug report on Github? FFS
