EnzoCastStream
I don't have that folder?Assuming you installed it with the provided installer just remove the following folder:
/Library/Application Support/obs-studio/plugins/advanced-scene-switcher/
Make sure you are not looking into your user's home directory Library folder, but the system's Library folder.I don't have that folder?View attachment 80358
I want to focus most of my development time on the macro tab.Would it be possible to add a import fuction to import a textfile with the "right" time?
If you go to Tools -> Advanced Scene Switcher, it is in the window title.How to view the current version number
It is useful, thanks!~If you go to Tools -> Advanced Scene Switcher, it is in the window title.
I hope I understood your request correctly.Could you make it possible to transition to the same scene in the Switch scene action? Would be very useful for showing/hiding items in studio mode, currently I'm hiding, setting it as preview and swaping preview/program. Making this possible would simplify things!
At the moment I have not planned on adding something like this - not sure how much use it would find.Also, is it possible to automate renaming scenes? I don't need the macros to adjust automatically, it's simply to help with a remote control program I'm using, more of a visual thing, not really important. Yeah it's pretty stupid but asking won't hurt I guess :P
I got around to working on your request.
I modified the date condition to also support switching based on just the day of the week and a time as shown in your screenshot.
You can switch between the old, more detailed view and this new one by pressing the "Show advanced settings" button.
A build with this change should be available here in a few minutes:
(Note that you have to be logged into GitHub to be able to download it - let me know if that is an issue)![]()
Date time check · WarmUpTill/SceneSwitcher@2e57a1a
An automated scene switcher for OBS Studio. Contribute to WarmUpTill/SceneSwitcher development by creating an account on GitHub.github.com
Let me know if everything works as expected! :)
Sorry, I should have worded it better... Let's say I have a scene called "Scene A". Scene A is already in program view.I hope I understood your request correctly.
I now enabled selecting "Current scene" (and "Previous scene") as a target for the "Switch preview scene" action:
A build with this change can be found here in a few minutes:
Note that you have to be logged into GitHub to be able to download the build.![]()
Allow selecting current and previous scene in preview scene action · WarmUpTill/SceneSwitcher@0c9a962
But thanks for the suggestion.
That's fair. If you're curious, I'm using an Android app to control my stream, and I can set icons for scenes. The icons are saved based on the scene name. I wanted to make a toggle-like scene, and make the icon switch accordingly (show on/off)At the moment I have not planned on adding something like this - not sure how much use it would find.
This entire post confuses me.Sorry, I should have worded it better... Let's say I have a scene called "Scene A". Scene A is already in program view.
Suppose I used a macro to hide some text, but since I'm in studio mode it doesn't hide immediately.
So I make it "switch" to the same scene, like this:
However, the transition never happens because I'm already in the scene
I want the transition to happen even if I'm already in the scene, so I can make changes inside the same scene while in studio mode.
Like I said, pretty stupid, do as you please :)
But I DON'T change to another scene.This entire post confuses me.
If I go to Scene A in my OBS and have a text file showing. I enable Studio mode. Change to another scene, then use my stream deck to hide that text => It hides it immediately.
That's not how transitions work. They go from A > B.But I DON'T change to another scene.
That's my whole point, I want the transition to happen, because while it hides immediately in PREVIEW, I still need to transition to PROGRAM
So is what you're saying that you want to hide your screen while you enable or disable a text?
In that case, could you not just put something on your screen (like the transition) in a Media Source file, drag it to the top of the scene (in sources) and enable that? Then it would play, and you could do whatever you want with text files.
I see what you mean.Sorry, I should have worded it better... Let's say I have a scene called "Scene A". Scene A is already in program view.
Glad you like the plugin!Hi, thanks for making such an awesome plugin! I have a VLC source playlist of unknown length (some amount of game highlights from a recent match) - is there a way to transition to a different scene just before the last video in the playlist ends? I understand the media transition has a "played to end" source, but that leaves a brief instant of black screen before the stinger rolls in. I would ideally set the transition to happen 500ms or something prior to the final video in the playlist finishing playing.
That makes sense! I figured it wasn't hooked out, so I guess I just need to manually do it. Is there a way to prevent the black screen that pops up as the playlist ends? It doesn't happen if the playlist just runs to end, only shows up with advanced scene switcher activeGlad you like the plugin!
I am afraid I don't think this is possible at the moment.
Last time I checked there was no OBS API to query the total length of a playlist.
But as you were not the first one to request this functionality in regards to playlists of unknown length I will try to see if I can maybe find a workaround.
I can't promise a solution soon though.
Hm, I am a bit surprised by that.That makes sense! I figured it wasn't hooked out, so I guess I just need to manually do it. Is there a way to prevent the black screen that pops up as the playlist ends? It doesn't happen if the playlist just runs to end, only shows up with advanced scene switcher active
Odd, I went to go check it so I could provide screenshots and now I'm getting the black screen 100% of the time, so I guess this is the expected response of VLC Media sources, which is frustrating.Hm, I am a bit surprised by that.
The plugin should not really affect the video output of the media source in any way, so I am not sure why the black screen is happening only when using the advanced scene switcher.
What is displayed instead of the black screen when not using the plugin?
What exactly have you configured in the advanced scene switcher in regards to that media source?
Works perfectly, thank you!I see what you mean.
A build where switching to the already active scene is enabled (while studio mode is active) can be found here in a few minutes:
Let me know if everything works as expected.![]()
Allow switching to already active scene if in studio mode · WarmUpTill/SceneSwitcher@779646c
Just in case you are not aware and it might be useful for your setup:
A separate action exists to allow you to swap the preview and progam scene.
When I show/hide something in a scene while in studio mode, the item doesn't immediately get hidden, you first have to run a transition to go to the changed stateThat's not how transitions work. They go from A > B.
