I guess I am not the first person asking this but I couldn't find an answer.
My issue is that I can't find a way to change scenes depends on if source(game capture) is active.
I've tried using Macros but it doesn't work. I'm not sure what does "is active" means. But I guess it means if that game is opened.
So I want to switch scenes from "League of Legends Client" to "League of Legends Game" when a game capture source capturing LoL Game inside "League of Legends Game" scene is running. And when it's not running, switch back to "League of Legends Client". But when I do it, it always switches to "League of Legends Game" scene for some reason. And if it helps, my game is on Borderless mode.
This is macros I've made:View attachment 78983View attachment 78984
The check whether a source is active will not be useful for your particular scenario, as a game capture source can be "active" even though there is not application being captured at the moment.
Instead it will probably make the most sense to check whether or not the particular application is running using the "Process" condition type.
(In the above example Firefox is used as I am not sure what the League of Legends process is called exactly.)
Alternatively you could also instead check the window title of the current foreground window.
If that should suffice for your use case you do not even need this plugin as OBS ships with the "Automatic scene switcher" tool which will allow you to do just that.
Let me know if that helps or if you have further questions! :)
Dzonzza
I've tried using "Process" condition type and it works perfectly fine!
I couldn't use "Automatic scene switcher" because that would change scene even if I Alt+Tab from the game.
Thank you a lot for helping me! :)
choops
is there something im doing wrong? all the other features of this patch work for me except for the transition overrides. this was the main reason i was planning on integrating this into my stream. thank you in advance if im just being dumb and overlooking something obvious!
is there something im doing wrong? all the other features of this patch work for me except for the transition overrides. this was the main reason i was planning on integrating this into my stream. thank you in advance if im just being dumb and overlooking something obvious!View attachment 79248
The entries on this tab only affect automated scene switches triggered by the plugin not manual ones - so maybe it was just a misunderstanding as to what this tab does?
If you a looking to control manual transitions I would recommend this plugin:
Or are you referring to automated scene switches which do not respect the entries on the transition tab?
If so can you give an example?
lindenkron
Is it possible in macros to have a macro with a hotkey that toggles between activating(running, just once) two other macros?
'Press R', Runs Macro 1
'Press R again', Runs Macro 2
'Press R again again', Runs Macro 1
Etc?
Etc?
Yes, that should be doable using something similar to this:
Let me know if you have questions!
But to be honest this seems a bit complex for such a simple task - I will try to think of a simpler way to set something like this up.
If you're going to do that, then I think it should at least support an arbitrarily long sequence instead of just two. Kinda like PowerPoint's advance button. And maybe include the reverse direction as well? Reverse probably won't work as expected for some things, like a transition to B that looks awesome coming from A and goofy coming from C, but the logic itself should still work.
That would almost be trivial with a Python tab and an API for the user script to hook into:
Python:
def sequence(x):
    match x:
        case 1:
            # trigger macro 1
            return false
        case 2:
            # trigger macro 2
            return false
        case 3:
            # trigger macro 3
            return false
        # etc.
        case _:
            return true
def init():
    step=0
def sequence_fwd(): # arbitrary name that is connected elsewhere to a hotkey
    step += 1
    if sequence(step)
        step=0
def sequence_rev(): # arbitrary name that is connected elsewhere to a hotkey
    step -= 1
    if sequence(step)
        step=max
Hans Bélanger
Hello everybody.
I'm having a hard time to figure out one detail of this plugin.
I use the switcher to automatically go to X scene once a vlc playlist has a few milliseconds left to play using the media tab.
My setup is like this:[When VLC Playlist Source state is Playing and Time remaining shorter ms switch to Previous Scene using Stinger Transition]
The issue I encounter is that the transition is triggered at the end of the first element of the playlist and so my question to you people is how do I specify to the Scene Switcher that I want the transition to trigger at the end of the playlist
Further information that could be relevant: a workaround that sorta works is to use the state played to end and trigger the transition then but there's a black screen during the transition as the playback is of course over. I guess I could cut to the previous scene but a transition proper is what I am aiming for.
Hello everybody.
Unfortunately, I don't think there is a way to to specify something like X ms before the end of the VLC playlist.
There is no way to query the size of the playlist as far as I know so something like this can only be worked around.
Even the "Played to end" condition type internally uses some workarounds to detect the end of playlist and ignore the end of individual playlist entries.
One possible workaround would be to just wait a set amount of time if you know the length of the playlist beforehand.
Another way would be - assuming the amount of items in the playlist does not change - to count the playlist items which ended their playback and only perform the scene switch only when the last playlist item is currently being played.
lindenkron
I think it worked the hotkey thing. Does seem a bit overkill though for the functionality.
I've also been having really weird issues with the new ADV-SS dock. I thought it was just me, or me being crazy to begin with. But I keep having it pop out or position itself in places & ways it shouldn't be able to, while locked.
Like this:
This is where it was originally:
Hans Bélanger
Unfortunately, the playlist's content varies both in number of items and total length. I'll stick to either triggering the transition manually or the workaround I currently use.
Thank you for the explaination, I had not realized that there is no way to query the length of the playlist
Glad to hear that it worked - but yeah I agree.
I started work on a "sequence" action to make setting up something like this easier:
(Still needs reordering / resetting the start / possibly more)
A build should be available here in a few minutes:
Oh OK, thanks for pointing that out!
Have you stumbled upon any way to reproduce the issue or a scenario where it occurs more frequently?
lindenkron
Nothing specific, I think it happens when you reboot though. This is what it looked like after closing and opening OBS. Also notice me trying to find the "grapping" points to extend the size, it appears gone.
This overlaps the minimum height of the dock itself when seeing how small you can make it. Now granted, I've not tried the dock in a different position - so it could be (?) surrounding elements.
Also;
Noted that macro actually doesn't work. When I boot up OBS from fresh, and press the hotkey it'll fire both macros, and they'll both go from 0 to 1 then 0. (So fire one, then fire other macro).
It appears fixed if I go in and disable 1 macro, press R, then enable it again, to offset the two numbers. Any idea for a fix to this?
Thanks!
lcalder
OBS will now always crash upon exiting in advanced-scene-switcher.dll on the new OBS v27.2.0 beta 2 and beta 3
Minimum Steps to reproduce:
1. Launch OBS
2. Wait for everything to load
3. Exit
4. Crash
Latest Windows 10. Last three logs and crashlogs below.
Please let me know if you need any other information.
  • 2022-01-17 18-32-58.txt
  • 2022-01-17 18-09-35.txt
  • 2022-01-17 16-20-41.txt
  • Crash 2022-01-21 17-12-48.txt
  • Crash 2022-01-21 17-19-56.txt
  • Crash 2022-01-21 17-20-57.txt
1. Launch OBS
3. Exit
4. Crash
Thanks for reporting the issue - i will look into it as soon as I can.
Update: I might have identified the reason for the crash on OBS exit.
A build with a fix should be available here in a few minutes:
(You need to be logged into GitHub to be able to download it - let me know if that should be an issue)
Also;
Thanks!
Thanks for the info regarding the dock issue!
I will try to look into it soon, but I will have to prioritize the crashes on the OBS beta for now.
Unfortunately, I can't think of a good solution to the macro toggle issue, besides using this new "Sequence" action from the build above.
@lindenkron I believe I found the issue regarding the dock's position not restoring properly.
A build with a fix will be available here in a few minutes:
(The above mentioned new action "Sequence" is also included)
Let me know if everything works as expected.
lindenkron
Thanks as always Warmuptill! I'll test it out after this weekends tournament.
I ran the first part of this weekends tournament, went okay! I did come across some stuff I'd like to ask if there's a way to do.
Is there a condition for 'if X application is in focus'? Because I found that my hotkeys that I set, would (obviously) also fire when I went to discord to type to people. Which was slightly inconvenient :D
Hope you have a great weekend.
