But it would be easier with one macro..i have many scenes and sources
A lot of things would be easier if it were designed specifically for them. But this is a general purpose thing. So there will always be some applications that don't really match up with how it works. Be proud of yourself for understanding how it does work, and using that to make it do what you need anyway.
That said, a checkbox to effectively create the reverse condition and action behind the scenes, might also be useful in a lot of cases beyond just that one...and probably hard to make in a general sense, because some actions don't really have a clear "undo" from the software's perspective.
"Undo" is one of those things that appear trivial to a user, but are nearly impossible to actually make happen. I've been there; I know! You need to design it in from the beginning, so that every action also saves the specific data that is required to undo it (when you as a developer still know what that data is!); or periodically save the entire state of everything so that you can restore one of those snapshots. The former requires a fair amount of explicit logic added to EVERYTHING; the latter requires a ton of memory. Either way, it still may not work right because certain things need to be set up again, and that setup has side-effects too.
In your specific case, I think it would work - "show" and "hide" are opposite functions without side effects - but it might be impossible to cover *everything*. That'll make it confusing when some things work and some don't. (maybe hide the "auto-undo" checkbox for the non-trivial actions???)
Or to make it even more generally useful, maybe have two actions: one for the condition becoming true, as it is now, and one for the same condition becoming false. The false action defaults to "do nothing", and there could be a button to set it to the reverse of the true action. Visually disable that button when the reverse is non-trivial. By allowing the false action to be anything, independent from the true action, it could create a lot of interesting behaviors, some of which might actually be useful! :-)
Maybe using the source action might be an option then?
This will allow you to globally disable / enable sources instead of just on specific scenes.
GraksO
Is it possible to run a scene switch when clicking the Start Streaming button? I tried using the stream running check condition but whenever I switch a scene afterwards it just goes back to the original scene (awesome plugin by the way)
GraksO
I may have figured it out??? I clicked the little clock icon and added a time condition of at most 1 second and it doesn't seem to be an issue anymore, but still wondering if there's a better way to doing this.
Adding a time restriction is the solution I would have suggested. :)
So I don't think there is a better way implemented at the moment, but feel free to suggest how I could improve it!
GraksO
just took a quick look at the documentation OBS provide and found this:
maybe it's possible to incorporate these into the plugin as an event which is called whenever the button is pressed, which in turn could trigger the macro (I have no clue if I'm using the correct terminology and my extent of programming knowledge ain't much so I might be very wrong about this)
Another way to do it might be to have a macro that both starts the stream and switches the scene, based on some other trigger. Then you don't use the Start Streaming button, but do that other trigger instead.
just took a quick look at the documentation OBS provide and found this: View attachment 76601
So what you are asking for is instead of a "stream running for 0 seconds" you basically want a dedicated condition type "stream started" that saves you entering the time restriction part?
If so I will add it to the todo list - should be rather easy to implement.
Btw. these functions are used to stop or start streaming.
OBS also offers "frontend events" like "OBS_FRONTEND_EVENT_STREAMING_STARTED" so you were pretty close :)
First, this is a great plugin...thanks to Warmuptill for all your work on it.
We use OBS Studio with this plugin for our church worship services. During long parts, we use the Sequence tab with hotkeys to enable/disable switching between our 3 cameras. Sometimes, it seems when we hit the hotkey to start/stop the auto sequence, it doesn't always work (but a second press of the key does). You won't know it is not running for 45 seconds, when the next camera is supposed to go live on the stream.
1) Is there an indicator on the screen, to let me know when the plugin is running? Example: I hit the hotkey to enable the sequence and the indicator turns on.
2) If not, does the plugin throw an event when it is enabled/disabled that I can catch in a script and make my own indicator?
I have implemented the option to display plugin state changes in the system tray.
A build with this change will be available here in a few minutes:
Note that you have to be logged into GitHub to be able to download it.
wilderf353
Great. I have downloaded it and tried it out. It works great on my home desktop. I will install it at church tomorrow too. Thanks again for doing this.
joshdreber
Hi all, I have another issue I'm hoping to get input on.
I want to be able to make OBS change the active scene automatically when an OpenLP slide is changed.
I have the advanced scene switcher plugin running, with various scenes and cameras running through a sequence based on time. For instance:
scene 1 is a ptz camera input for our pastor.
Scene 2 is a split input with that camera and a openlp browser input for slides.
The scene switcher runs automatically, 3 mins on pastor only and 1 min on pastor/slides. I want to have the switcher be interrupted and switch to scene 2 when a slide is changed in openlp, if OBS is currently on a scene with just the pastor.
Any thoughts on this or if its even been done? I've got the openlp custom browser dock switching slides from obs -> openlp, but I want it the other direction. The browser input scene works fine for showing slides.
Is there a way for OBS or the advanced scene switcher plugin to detect a slide/input change through the browser, and trigger a change of active scene to one with slides?
Essentially I'd like to eliminate having someone man the OBS machine and have it all automated based on what the openlp man is doing.
Thanks!
Thanks!
So, when a source changes, switch to a scene? I believe that's been discussed here before. Something about a DIY security system, I think, with OBS auto-switching to a camera with motion and recording the result? And needing a sensitivity setting so that leaves and vermin wouldn't trigger it. I'm sure a slide change would be more than enough.
I also remember something about needing the source to be rendered somewhere for it to work. A minimized projector from OBS is enough, but the source alone isn't. I'm not sure how these two points work together, so I might have some things confused.
(or maybe they didn't work together, and that was the discussion?)
If I might suggest something, I think it would work better as a finished product, to have a scene that has the slide overlaid over a corner of the camera. "Picture in Picture", to use some old terminology. Switch to the full-screen slide when it changes, stay there long enough for people to read it, then go to the PiP scene to keep a reminder of what it was, and stay there indefinitely. Don't time-out from the PiP scene. If the slide goes blank, take it away instead. (switch to a scene that only has the camera)
It might take some trial-and-error to make that work, but I'm sure the logic is possible with the current tools, assuming that the source-change-detector works.
Thanks!
You can try using a macro similar to this one:
But as mentioned by @AaronD you need to be sure that the source output is being rendered.
Otherwise the scene switcher cannot notice that the output would have changed.
If your particular source is not part of every scene in your scene sequence and thus not always being renedered you can open a "windowed projector" of the source to work around this issue.
Make sure to mark your scene sequence to be interruptible by clicking the corresponding checkbox.
joshdreber
Dude, this is the second time in a week you've saved my bacon. I should stop trying to figure it out and just ask you directly XD. Thanks much, I'll report back after trying it out in our services. I foresee a loop issue where the macro runs and switches to a separate slide scene when its already on one, if it detects a change, but I'll try to see if there is a condition or lock I can add that prevents that.
Edit: I did end up using a video source that lets me list my browser input, which is weird that I can't just select browser input with the "changed" option, but if it works, great. Not really sure how OBS renders everything between scenes because I certainly don't have that browser input on all scenes, but it seems to switch how I want it regardless.
bcoyle
Well said. I've been working on a 24/7 broadcast app and have put a few undo's in the app. But as you said, it's hard. I put them him specific places where I found the action would be terrible hard to undo manually. You are a wise man.
AlexYa
It is very difficult to say what the issue is without further information, unfortunately.
What type of media sources are you using?
Does the issue occur if you have only the rule for "Video B" set up?
I am not sure I understand how using macros makes a difference - are both video sources in state "ended" at the same time?
If so then the scene switcher uses the higher priority rule to decide which scene to switch to.
(As otherwise the plugin would continuously switch back and forth between the two specified scenes)
I have the same problem as mr. Urbanian.
My goal was to make promo inserts between the clips from the playlist.
The workaround is as follows:
Two scenes, A (A: VLC source with playlist; loop; paused on hiding)
And B (B: Source with simple media source with promo; restart on active)
I made two macros:
1) From A to B: If A:VLCSource is "ended" - switch to scene B
2) From B to A: If B:Source is "ended" - switch to scene A.
And it wasn't works. Plugin even not switched scene A to B at all. Only B to A.
Already I've tried use not macros but Media rules instead. They not work at all (tested with "ended" and "played to end" events)
BUT! I've founded the solution "from the reverse"
I changed macros 1) to next:
From A to B:
    If A:VLCSource is "playing" and "time remaining shorter" than 1-2 second:
         switch to scene B,
         switch next track in A:VLCSource,
         pause it at the moment.
Therefore, I came to the conclusions:
a) the "ended" event does not work for VLC Source (OBS level or plugin?)
b) Media rules do not work properly
c) When the "loop" setting is enabled in VLC, the "played to ended" event does not work either.
  • Test_advanced_scene_switcher_with_tab_Media_and_VLC_sources.txt
  • Test_advanced_scene_switcher_with_tab_Media_and_VLC_and_media_sources.txt
  • Test_advanced_scene_switcher_with_tab_Media_and_media_sources_(played_to_end).txt
  • Test_advanced_scene_switcher_with_tab_Media_and_media_sources.txt
  • Test_advanced_scene_switcher_working_configuration.txt
I made two macros:
From A to B:
         switch to scene B,
If a VLC source is containing a playlist that is looping forever it will never reach the state "ended" or "played to end". (Or at least that is my assumption)
As you have correctly identified you can use the "time remaining shorter" to identify individual playlist items coming to an end.
If you have suggestions on how to make this more clear I am all ears! :)
Should I maybe introduce a separate state called "playlist item ended" or something similar?
Below is an example on how to set up automated commercial breaks on fixed interval, but not interrupting individual playlist items.
Hope that helps.
I know you have already set up your media source correctly but for completeness in case others want to replicate the setup:
The important part is the "Pause if not visible, unpause when visible" so that the playback does not restart when switching away and back to the scene containing the VLC source.
Next we will need two macros.
  1. The first macro is responsible for detecting when a transition to the next playlist item takes place and if the specified time interval, after which a commercial shall be played, has passed.
    If both are the case a scene switch will take place.
    You can find a screenshot of the settings I used here:
    The media condition with state "playing" and "time remaining shorter than 1 second" restriction will allow us to identify when the current playlist entry is about to end.
  2. The second macro is only responsible for automatically switching back to the scene containing the VLC video source playing back the playlist.
    A screenshot of the settings I used for testing can be found here:
    The important part is the macro action to reset the timer of the first macro described above.
    Note that the media action is probably not strictly necessary, but I added it just in case.
This setup allows to automatically switch to a "commercial" scene if at least 30 seconds have passed and when a playlist item just ended its playback.
ghaleon
Fresh win 10 x64 installed, fully updated. Fresh OBS install with streamlabs. Installed the latest version of Advanced Scene Switcher and OBS crashes on startup. Been having issues with OBS crashing for a while before this, I think ASS was always the main culprit?
  • 2021-11-01 16-18-58.txt
