Lycanthrope -R-
Oops. Must've missed that. Thanks for pointing it out.2. You can configure how the plugin will behave in regard to transition overrides on the General tab.
Having this same issue!I am very sorry about that!
I will try to look into it as soon as I can (which probably will only be tomorrow, unfortunately).
Which version of the advanced scene switcher are you using?
Which OS are you using?
I thought I had tested the latest advanced scene switcher release with the OBS 32 beta releases and it was working fine.
I will make sure to verify that again tomorrow.
If you haven't done so already it might be worth a shot simply installing the most recent release once again.
Pinging @Daniel-House-1242 since he reported the same problem.
Just to avoid a misunderstanding: You seem to facing a different kind of issue.Having this same issue!
On Windows 11
Using Advanced Scene Switcher 1.31.0
OBS Version 32.0.01
Plugin no longer works, and brings up the prompt, "The plugin installation seems to be corrupted and might crash! Please make sure the plugin was installed correctly!". Was working fine before updating my OBS about a couple weeks ago. Thank you in advance for the help!
Hi again,I will try to look into it.
What do your macros look like?
Maybe I can think of a workaround.
That should be doable using a macro like this:
You will of course have to adapt the channel name, the "!MyChatTrigger", and scene accordingly.
You can find a first release which supports getting sources from other canvas' such as the Aitum Vertical plugin here on GitHub:Hi again,
I can see that Exeldro has now updated the Aitum Vertical plugin to 1.6.1 with:
- Add option for other plugins to get and switch scene
Could you please look into this so that our vertical scenes/sources based on the new OBS canvas system could be used again in our Advanced Scene Switcher macros?
99% of my macros are currently based on Scene Item visibility leading to a chain reaction once a vertical source is shown.
The most likely scenario is that at some point you have manually moved the location of your OBS installation.Hello! So I had updated both OBS and Advanced Scene Switcher to the latest versions, but Adv Scene Switcher is not showing up underneath the TOOLS tab. I've tried uninstalling and reinstalling multiple times to no avail, and would just like some insight about the problem with a possible fix. Has this problem come up before?
I went and installed OBS and all under the C Drive, and things were recognized instantly. Thank you so much!The most likely scenario is that at some point you have manually moved the location of your OBS installation.
In that case the installer is assuming OBS is at a different location on your filesystem compared to where it actually is and puts the files in the wrong location.
You can work around this problem by manually installing the plugin using the contents of the zip archive.
Installation
An automation tool for OBS Studio. Contribute to WarmUpTill/SceneSwitcher development by creating an account on GitHub.github.com
