KensonPlays
It won't let me edit, but I finally made a small tweak to make it work in that game. I had to uncheck the top 2 boxes and a couple small tweaks. Took me 3 hrs to figure it out on that one game. But now, it won't work in Monster Hunter.
I'm in a group waiting for a hunt to start, it detects the image, but it isn't switching scenes at all. It stays in the Game scene, even if it matches exactly, it won't switch to Chill/Intermission. The games are both full 1440p resolution on my monitor,
I basically copied the other one and changed the screenshot it reads from.
StadiumPK
If you should run into issues please do let me know about them! :)
Hi there,
It's checking for it great, but now I have a different issue. I am trying to mock the game message as a reasonable test, but it is not working for me.
I have text on another layer that is then screenshotted and saved as a PNG, so it is white text on a transparent background. I also tested with a screenshot of the games background, and neither are matching. If I test with my character name from a screenshot of the game, it works fine...since it is more of an exact match.
I have tried to match the font etc, but I had figured it would pick up the text.
Any suggestions?
Here are some screenshots, if I make the threshold 0.01, no difference. Hoping I have missed something simple :)
phillymantis
had the most random idea....
and its about "random" ....it would be cool if instead of adding macros 1by1 to the random list
we could add a colleciton of macros...
right now when i uncheck macros i have to also remove them from the random list...that would be super dope
Feature request (or clarify if this is already implemented).
1) When "Copy"ing a macro action, it can only be "Paste"d to an "Action" region with the same type (Actions vs Else-Actions). For example, if a copy a macro action in the "Else Actions" section, it can only be pasted in another "Else Actions" of macro. The action cannot be pasted in the "Actions" section of a macro.
2) Add "rename" of the custom label to the context menu. Today, my work around is to choose "Use custom label" twice if I want to rename a condition with an existing custom label.
I am using Windows / v 1.26.4
Thank you.
If the pattern is recognized correctly in the "Show match" dialog then the issue must be somewhere else.
Can you please enable verbose logging on the General tab, reproduce the issue, and share the log here?
Then it should be rather easy to find out why the action is not performed.
If that shouldn't bring any new insights I am also open to join a call on Discord where we can debug the issue together.
Hi there,
Any suggestions?
You will probably have to check the "Use alpha channel as mask for pattern" option.
With your current settings the pattern matching algorithm is looking for the transparent parts of the input image as well, which it cannot find in the given source.
You will probably get the best results, if you create a screenshot of your source using the "Browse -> Create Screenshot" option of the Video condition, and modify this screenshot to make the parts of the image you don't care about transparent.
Then you can rely on the "Use alpha channel as mask for pattern" setting to just look for the relevant parts of the screenshot.
I hope it is somewhat clear what I mean :)
Alternatively maybe using the "contains text" check of the Video condition might also work depending on how "noisy" the image output of the source will be.
I will add it to the todo list.
Just in case it is of use.
The "Random" action type will skip over macros which are paused.
Thank you.
Thanks for the suggestion!
I will add it to the todo list :)
StadiumPK
Ok ends up the contains text worked amazing well however, is there a way that I can control that text field without having to go into it each time? Ideally I could set a command or something that updates that text field, or have a text layer be assigned to it? Ideally a .text file would be perfect, like "stadium slain by" would be in the text field and the contains text would compare against that file.
Also it only matches when partial match... weird lol.
There is a way. :)
Instead of typing in the text directly you could reference a variable instead.
You can then control the value of the variable via a separate macro. (For example by reading the value for the variable from a file)
This can be configured by clicking on the regular expression button. (.*)
all i come with lately is bad news ;) updated, and trying to access a certain macro to edit and obs crashes...
I believe I was able to identify the issue.
A build with a fix is available here in a few minutes:
Can you please confirm that the issue is no longer reproducible on your side when using this test build?
You will have to be logged into GitHub to be able to download it - let me know if that should be a problem!
Looks fixed for me, I checked more then the ones that led to a crash, all opening fine now.
obsuser2023
Hi, I noticed, if another app is running in full screen, Advanced Switcher will not hear the hotkey press. If unfocuse the full screen app, Advanced Switcher can hear the hot key press. I guess this is a limitation? Thank you.
You might get it to work by adjusting the OBS hotkey focus behaviour:
some apps are dumb, i have one that needs to run in admin or it wont listen for hotkeys, maybe try that
BreezzersGaming
I'm pretty new to OBS, 3-4 months, I'm streaming to multiple platforms simultaneously YT 4k, YT Vert, Twitch,
I was following Michael Feyerer's tutorial youtube.com/watch?v=mLN5LxL9kCE&list=WL&index=5&t=507s for switching the scenes Vertical and layouts and I can't get the vertical scene to change for the life of me, i don't want anything else to change other than the Vert scene. I have the layouts all done, just trying to automate the process
I'm trying to get the Switcher to just switch the scene in Vert mode. Is this possible? I'm on a dual stream rig, capture card
Unfortunately, if you want to change only the vertical scene and not a "linked scene" it get's a bit more complicated.
The vertical scene cannot be directly changed by an OBS API call as OBS does not know about vertical scenes.
The vertical canvas plugin does however expose the option to change those scene via websocket messages.
So, that means you will have to use the "Websocket" action type to change the scene.
An example how to do this can be found here:
