Rozenman
I checked - I replaced the names of folders and files exclusively with Latin ones. Unfortunately, it doesn't work.
[{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/2 Dafne monaster.jpg"},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/3 Dafne monaster.jpg"},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/4 Dafne monaster.jpg"},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/5 Dafne monaster.jpg"},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/6 Dafne monaster.jpg"},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/7 Dafne monaster.jpg”},{"hidden":false,"selected":false,"value":"/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/1 Dafne monaster.jpg"}]
Bairespm
Hi, maybe you can help me with something
It's probably very simple and I'm not realizing how to achieve it.
In a scene A I have 4 videos, and I need the following to happen
video 1 - play
when it finishes playing
video 2 - play
video 3 - play
video 4 - play
Change scene to "X scene"
I clarify: "Sequence" does not work, it only runs the first macro but does not continue with the following ones automatically for it to do so I must change it manually
I clarify something else,
VLC playlist does not work either, because in some videos that have audio at the beginning, it plays them cut off, it is not fluid. between video and video
I have achieved it by making 4 scenes with 1 video each, and then a macro that controls the playback when it ends to change the scene.
Even so, I am looking to simplify it into a scene and a macro, which is why I am asking for help here.
thanks for your time.
any idea? @Warmuptill
video 1 - play
video 2 - play
video 3 - play
video 4 - play
Your "workaround" here, is what I would do anyway:
(last macro in that set of three)
I have lots of scenes with few things in each, usually just one in each, and switch scenes instead of sources. Seems to work much better that way, like PowerPoint slides except with live media.
If you're getting lost with so many "slides"/scenes, use their names to help organize. I have a naming convention for a different purpose - some of my macros use regexes on the current scene name to do different things for different categories - but I think you get the idea:
The Open Sound Control action controls the DAW that handles all of my audio. OBS is silent except to get a video soundtrack out of it and into the DAW, and to get the final mix out of the DAW and into the recording/stream.
The Websocket action controls a second instance of OBS, which also has Adv. SS, so that all the production work can be done from this one.
This rig has two simultaneous outputs, that are different enough to need two complete instances. I *might* be able to use the projector and Source Record plugin creatively to make one instance do both, but it's a lot more straightforward to have a dedicated instance for each, and connect their controls like this.
Bairespm
Thank you but I don't understand, I don't think it's what I really want to do... you are probably referring to another question that may have been asked.
One of the quotation mark characters results in the string not being valid JSON.
A is used instead of a ".
This is the reason why nothing happens.
You can find the fixed JSON string here:
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/2 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/3 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/4 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/5 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/6 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/7 Dafne monaster.jpg"
        "hidden": false,
        "selected": false,
        "value": "/Users/alexeyshadrin/Dropbox/@ 1 PROFILE SCHOOL/@ NATIONAL ART/TEMP/1 Dafne monaster.jpg"
Hi everyone
Can sombody help me how to do the next function:
"wait until scene is current then do"
I think I will need more information about what you are trying to set up.
In general if you want to "wait for a scene" you should probably use the "Scene" condition type.
I guess you could simply set up a number of macros similar to the following:
You might have to configure your media sources to not automatically play when switching to Scene A.
Hope that helps! :)
Bairespm
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
        "hidden": false,
        "selected": false,
Hope that helps! :)
Thank you, but what I need is for each time I go to scene A to play a different one randomly, not to repeat it until everyone has passed. Is it possible?
I might have done a bit of a stretch all at once.
For the immediate question, I'd do it the way that I linked, not the rest of that last post.
The way that I linked makes a LOT of scenes, which might need them to be better organized than just a flat list. Thus, the naming convention as a sort of folder structure without actually having folders.
Then there's what *else* you can do with that naming convention...
That's the first time I've seen that you wanted random.
Back to the separate-scene-per-thing, you can then have a macro for each that simply switches to its assigned scene. Then use the Random action to pick which of those macros to run.
Again, OBS really seems to work a lot better if you have a bunch of simple scenes. Don't try to use the scenes themselves as folders.
But if you really had to, I guess you could set up each of the individual macros to reconfigure the one giant scene. Then the "master" macro has at least two actions: 1) Random to pick one of those configuration macros, followed by 2) Scene Switch to that one giant scene.
Rozenman
Understood. There was an idea that couldn’t use regular text editors. I tried a specialized JSON-editor and it worked. Thank you very much!
fencer
Yes, you are right, I want to make function's work when I have sequence of scenes and I want to record all of them when the sequence is changed.
I made macros:
- to turn record on when the 1st scene is current ,last scene is previous and recording is off;
- to turn record off when the 1st scene is current ,last scene is previous and recording is on;
Now Im looking for solution how to check scene sequence with timeout and if it had changes turn record on the 1st scene starts, and turn record off when the last scene ends.
I made macros:
So...every time you transition from scene A to scene B, you want the recording to toggle? On that specific transition, if it was running, you want it to stop; and on the same transition, if it was stopped, you want it to start?
If so, then you might do something like this, just off the top of my head:
  • Variable:
    • State Machine
  • Macro: Detect Transition
    • Conditions (only on change):
      • If Previous Scene is A
      • And if Current Scene is B
    • Actions:
      • Variable "State Machine" = "TOGGLE"
  • Macro: Start Recording
    • Conditions:
      • If Variable "State Machine" == "TOGGLE"
      • And if Recording Stopped
    • Actions:
      • Variable "State Machine" = "RUNNING"
      • Recording Start
  • Macro: Stop Recording
    • Conditions:
      • And if Recording Running
    • Actions:
      • Variable "State Machine" = "STOPPED"
      • Recording Stop
You could probably do the same thing with just two values of the "State Machine" variable, with the two blocking values (RUNNING and STOPPED) being the same, but having them different makes it slightly more readable, and could allow yet another set of macros to know the status of this machine just with that, and do something accordingly. (if the Start or Stop macro is paused, then the State Machine variable will stay as TOGGLE...)
ndfan77
@Warmuptill, et. al.
Before I jump into a rather detailed set of questions I'd first like to say I greatly appreciate Adv Scene Switcher, and the time and effort you've obviously put into it.
I hope I'm not overlooking something, but after spending several days digging through Adv Scene Switcher functionality (and searching) I can't find a "clean" way to do something that seems fairly common.
We stream twice a week -- once on Wednesday and again on Sunday (worship services). The Wednesday stream has a dedicated stream key and the Sunday stream has a dedicated stream key. There's nothing else different between the services (as far as OBS goes), so only one set of (rather involved) macros is needed to manage the OBS life cycle for both services (which are triggered by hotkeys, either directly, or indirectly through an AutoIT menu).
So..., in our case it seems like we need a way to conditionally set an Adv Scene Switcher variable based on day of week -- in the actions of a macro (not as the trigger). So the hotkey-triggered macro that manages the livestream startup for both Wednesday and Sunday can conditionally set the right stream key based on the day of week before starting the livestream -- within the list of actions for that macro.
I initially tried using a different macro (triggered by date / day of week) to set an Adv. Scene Switcher variable to the appropriate stream key (and then the macro that starts the livestream used that variable to set the OBS stream key before starting the stream). But..., if "Perform actions only on condition change" is enabled, Adv. Scene Switcher doesn't always run a macro triggered only on day of week (my guess is that if Adv. Scene Switcher isn't running when the day of week actually changes at midnight, it doesn't recognize the macro hasn't fired yet when OBS starts on a different day). If "Perform actions only on condition change" is not set, there is no reliability issue because the macro is running every 300ms, 100% of the time -- which is almost certain to occur before the livestream startup macro is initiated by hotkey. But..., having a macro run 3x a second 100% of the time just to make sure a variable is set accurately based on day of week, doesn't seem like a particularly clean/elegant approach.
If a macro triggered only on day of week shouldn't immediately trigger the next time OBS is run on a different day by design (the macro is ordered above the macro that manages livestream start), than it seems like the next most-elegant way(s) of potentially addressing this need would be:
  • Having a way to set Adv Scene Switcher variables to a program's stdout output (so we can call PowerShell to produce a needed value).
  • Or, a way to set Adv Scene Switcher variables to a program's exit code, and then:
  • Have a way to conditionally set an Adv Scene Switcher variable based on another variable's value (preferably with a value for true and a different value for false).
From what I can tell the ability to do things conditionally within macro actions is currently a bit limited in this regard(?) -- unless I missed something?
So right now I'm resigned to thinking the only way to cleanly set the stream key based on day of week is to have AutoIt set an environment variable to it before launching OBS. (But that's also not as clean as I'd prefer because it means AutoIt has to know about stream keys and, the environment variables won't be set if OBS is started separately from AutoIt.)
TIA...
I'd like to make a feature request. I've only started using this awesome plugin for a short while, and there's two minor issues I have with it:
  1. The UI doesn't save its window size, requiring you to manually drag and resize each time you open it again. I'm not sure if this has to do with OBS' core UI elements themselves, but if possible it would be great if we had a maximize button and/or saving window position.
  2. The Macros tab doesn't make full use of a traditional monitor's horizontal screen estate. Coupled with #1, it is especially more evident when a given macro gets complicated with extra conditional checks and actions to perform (and that's not counting the else actions). Therefore, it makes more sense to use a three column layout ('else' actions included). A toggle to switch between the two layouts would be ideal, that way we can account for folks using vertical monitors.
TIA...
Soo...:
  • You need to keep everything the same, including changes, except for a different specific stream key depending on the day of the week?
  • The macro that sets that stream key also does a lot more that needs to stay the same?
That screams to me to use a variable, set by its own dedicated macro or set of macros (one for each day of the week, with just that one action), but:
  • Setting that variable doesn't work reliably?
Now it seems to me like a "race condition", as the software world calls it. If the code that uses something, happens before the code that sets it, then of course it doesn't work right. If you have variable timing between those two parts, then sometimes it works and sometimes it doesn't, and that variable timing can be wildly random compared to the system speed. Does that sound like what it's doing? If you look at the variable afterwards, is it correct, and that correct value was not used?
Do you have the box checked to "run in parallel"? If my understanding is correct, the macros that don't, run sequentially, down the list in that order. The ones that do, all (nominally) start at the same time as the rest of the list does. What actually happens is that the system schedules them to run in whatever time slots it has available at that moment, and it's effectively random which of those "threads", as we call them, actually runs first. (or which ones actually do run together, on a multithreaded CPU - but the entire system has hundreds of threads, and the CPU only has 4 or 8 or something like that, so the scheduling is still necessary and still ends up sequential in a practically random order)
Multithreaded reliability is not trivial at all! Only if it really would work on completely separate, unsynchronized machines, does the complexity collapse into something easy to think about. So if you need them to interact closely, don't run them in parallel. If you then need that to respond faster, make it scan faster (decrease the interval). Mine is set as fast as it goes, at 50ms, just as a matter of course.
I've been saying occasionally for a long time, that this has already become its own programming language. Probably even Turing Complete. Treating it like that, reveals some glaring omissions compared to most programming languages, one of which is inline conditionals.
For the list of non-parallel macros, you might imagine this pseudocode:
C-like:
while(true)
    sleep(SCAN_INTERVAL);
    if (MACRO_1_CONDITIONS)
        MACRO_1_ACTION_1;
        MACRO_1_ACTION_2;
        MACRO_1_ACTION_3;
    if (MACRO_2_CONDITIONS)
        MACRO_2_ACTION_1;
        MACRO_2_ACTION_2;
        MACRO_2_ACTION_3;
    if (MACRO_3_CONDITIONS)
        MACRO_3_ACTION_1;
        MACRO_3_ACTION_2;
        MACRO_3_ACTION_3;
What it doesn't do, and would be incredibly useful, is:
C-like:
while(true)
        MACRO_1_ACTION_1;
        MACRO_1_ACTION_2;
        MACRO_1_ACTION_3;
        MACRO_2_ACTION_1;
        if (SOMETHING_ELSE)         // <--------
            MACRO_2_ACTION_2;
            MACRO_2_ACTION_3;
        MACRO_2_ACTION_4;
        MACRO_3_ACTION_1;
        MACRO_3_ACTION_2;
        MACRO_3_ACTION_3;
At that point, why not add a python tab? It's already a mature language with a TON of features in addition to this, and lots of existing documentation and tutorials, and designed for beginners to pick up quickly and "just use". Each condition would then be a function with arguments/parameters that returns true or false, and you'd put them in your own if's and use python's logic to combine them. Actions would also be predefined functions in the new Adv. SS library...
A "code generator" might be useful as well, mostly to discover what exists to be able to use, and that could be heavily based on the existing GUI. Just limit the generator to one condition or one action, and a button to either put on the clipboard or insert at the cursor, the function call that corresponds to what it's set for at that moment.
Rozenman
I think I know what you need. Look. This won't solve your problem specifically, but it's a general principle:
Macro 1 by date starts something, does something.
Macro 2 by date starts something, does something.
Etc.
Then, a separate macro works like this:
If Macro 1 or Macro 17 or Macro 328 is true, then load such and such a stream key into a variable.
Example in the picture. Sorry for the non-Latin text here and there.
The macro should be still be executed at least once when the plugin is first started.
The plugin does not need to "witness" the day actually changing.
You should be able to verify this with such a test macro:
And checking the value of the variable after starting the plugin on the variable tab:
If this *does not* work this would definitively be unintended behavior.
In that case I would be very interested in what you have configured so I can fix it.
You could share the setting by exporting them to a file.
The performance impact of those date checks / variable assignments should be minimal. (Just in case that is one of your concerns.)
But as mentioned before I think the approach with having "Perform actions only on condition change" enabled should work unless something is broken.
This should be possible already thanks to @Destroy666! :)
It is indeed very limited.
I understand and agree fully that this would be very useful to have.
But I always have to weigh it off against the time I have available and restructuring / redesigning the plugin to support this is unfortunately not an option for me at the moment.
What I could maybe do without too much effort is to add some of that functionality to the "Macro" action which already lets you run the action of other macros.
Adding a checkbox to only perform those steps if the conditions of the selected macro evaluated to "true" might be quite straight forward.
It is a great idea and sounds like fun project but I simply lack the time to implement this.
But I do appreciate the suggestion nonetheless! :)
Yes, it would be a lot of work to add that functionality into the format that presently exists. Hence the completely different format, and the note that that different format already exists, so why not use that.
Keep the GUI, mostly as-is - maybe even simplify it: remove the more confusing parts, or the harder things to maintain - and have it be a "Lite" version that is still graphical. Easy to use, and kept that way. Intentionally limited to avoid confusion. Then have the python tab that can do absolutely anything at all, but requires knowledge of python (and in the more complex cases, software management) to do it.
If you do *remove* functionality though, then you'd need a migration tool that converts an old macro into an equivalent chunk of python code. Given the limited nature of the macros by comparison, that shouldn't be *too* hard once you get going, but it's not trivial either. Good design up front would make a big difference, and would almost certainly become a tradeoff between up-front translation, and ongoing ease of use and maintenance.
(Mile-long string of parameters in a single function, vs. several functions to build up an underlying state that is used by the final function, for just one example. The latter of those options would probably be more readable, and allow keeping the same state across many "final" uses, not that the automated translator needs to know about the reuse. It can rebuild the state every time, and I'd call that "okay".)
Generally, it's a good amount of work up front, for hopefully a lot less work later if you do it right! New functionality, if you want it to appear in both places, then involves the GUI once, and the underlying code once. Both are inherited by both tabs, in different ways: the macros as they are now (possibly with the "complex software" functionality removed), and python as the code generator and library function(s).
That would be a good workaround at the moment, if you're really against the python tab.
But I think there'd have be *two* separate macro selections. One to run the actions of and one to check the conditions of, not necessarily the same. That avoids a maintenance nightmare on the user's end, with a big pile of macros that all have identical actions and different conditions or vice-versa.
And it also solves the problem of these macros just running on their own, since they have both conditions and actions. Now they don't have to: conditions with no actions does nothing on its own, and actions with no conditions also does nothing on its own. Then use this new functionality in the Macro action to put them together.
Of course, if you only had a checkbox and not a second selection, the maintenance problem could still be lessened if all of the condition macros had a single Macro action, that pointed to the actual code to run, but that's getting pretty silly and convoluted. And they'd all have to be paused, and their conditions as checked in the Macro action would still have to work when they're paused.
Not that that wouldn't be a workable chip design, along with a C or higher-language compiler that sorts it all out for you in the background...but it gets pretty clunky on a "chip" that you're designing to be directly hand-programmable in assembly, as Adv. SS macros kinda are.
I'd still consider it to be a non-ideal workaround though, mostly because the complete conditions and complete actions are not directly visible next to each other in context. That's also a problem in other languages when you share behavior across different parts of the code: a poorly-named function (macro in this case) that's used everywhere leaves you scratching your head about what it does, and you have to go track it down and read its code to find out.
