gamerino
Ah, the problem is quite simple - thanks for sharing the log!
Your OBS version is too old and does not support this feature.
You will have to use at least version 29.1.0.
I will see if I can add some sort of version check to not even show this condition type in that scenario.
OHHHH. dang it! I was running obs 29.0 and thought it was fine.
everything is working now, thanks for the help!
struth
Running v 1.23.1 on OBS 29.1.3. I have a simple macro that triggers when the modification date of a certain file changes. It works fine, but the macro is also triggered at OBS startup, as though the adv-ss plugin didn't know that the unmodified file was already there. How to deal with this? Thanks!
I can think of two ways of solving this (there might be more):
  • Add a "and not plugin started" condition to your macro:
  • Mark to macro to be skipped on startup.
Hope that helps! :)
tony_from_coffs
Current version of ASS crashes load of OBS 30.0 Beta 3, is it just me?
MacOS Ventura on Mac Mini M2 Ultra
ThankYou..
See attached report
  • OBS_30_ASS_crash_Report.txt
ThankYou..
See attached report
From August 17 (back 2 pages, so it took a while to find):
Important information for MacOS users:​
If you are running the OBS 30 beta releases on MacOS, the official releases of the Advanced Scene Switcher plugin will not function. In fact, having the plugin installed will result in OBS immediately crashing on startup and prompting you to start in "Safe mode" without any plugins!
Other platforms are *not* affected!
What do I need to do?​
The first step should be to back up your existing settings while using the previously compatible version of OBS again.
You will have to do this for each scene collection.
If you want to continue using the Advanced Scene Switcher plugin with the OBS 30 beta, you will have to use this development release of the plugin:
https://github.com/WarmUpTill/SceneSwitcher/actions/runs/5741802989?pr=800
Note that you will have to be logged into GitHub to be able to download it.
Also note that this version of the plugin is not compatible with OBS versions older than OBS 30.
Why is this happening?​
This is happening due to an incompatibility in the asio library, which was updated to version 1.28.0 with OBS 30.
The plugin will switch to this new version once OBS 30 was released officially.
(This information was also shared on GitHub)
A new *beta* release of the plugin can be found here:
If you have the chance, I would appreciate if you could give it a try and report back if you encounter any issues! :)
Important notes:​
Please make sure to back up your settings!
If you run into any issues, please either post in the OBS forums or create an issue on GitHub!
Note for MacOS users:
This version of the plugin is *not* compatible with OBS 30 beta versions.
More information can be found here.
OBS 30 compatible versions will be released once OBS 30 leaves its beta phase.
This does not affect Windows or Linux.
Additions:​
  • Added the "Twitch" action, which will allow you to ... Twitch
    • Set the stream title
    • Set the stream category
    • Create a stream marker (Destroy666x)
    • Create a stream clip (Destroy666x)
    • Start a commercial
  • Added an "else" action section to the macro tab.
    This should allow you to simplify your macro setups if you previously created separate macros for the "else" branch.
    Here is an example of the "else" section in use:
    ElseAction
    This unfortunately comes with a minor breaking change:
    Previously, the "Perform actions on condition change" would also affect how the condition state of a macro was evaluated.
    Macros with this option enabled would only be considered to be evaluating to "true" for the interval in which the conditions turned true.
    Now they are considered to be evaluating to "true" in this scenario and the "on change" option only has an effect on if the actions are performed or not.
    This could cause issues if you were previously relying on this behaviour in combination with the "Macro" condition type, but this should hopefully be very niche.
    This was necessary to be able to support the "else" actions also being affected by the "Perform actions only on condition change" option.
    (And I also think it makes more sense logically as the option only mentions actions being affected)
  • Improved the "Variable" action by adding the option to ...
    • Set a placeholder text when asking for input
    • Set to the value of a given environment variable
    • Set to the value of the count of scene items of a given scene (to enable iteration over scene items)
  • Added French locale. (lMagickl)
  • Added option to check for settings changes to the "Source" and "Filter" condition.
Other changes:​
  • Moved the action to switch the preview scene from the "Studio mode" action to the "Switch scene" action.
    This change will not affect existing "Studio mode" actions.
  • Windows only: The "Window" condition type will now also list OBS windows instead of only the placeholder entry named "OBS".
    For example, this will allow you to check if a projector window is already opened.
  • Reset monitor selection in "Projector" action when monitor setup changed, instead of defaulting back to the new monitor at the same index of the previous monitor setup.
  • Only show the "Slide Show" condition type if the installed version of OBS supports necessary features.
  • Added the option to reduce CPU load of the "Video" condition's "has changed" checks by reducing the frequency at which the output is checked.
  • Added option to disable filtering by typing in various selections.
Fixes:​
  • Fixed the "Video" condition's OCR value not being assigned to variables when the use of regular expressions was enabled.
  • Fixed crash on shutdown related to macro docks.
VitalyMetelev
Hi guys, can I use macro for scene switching? I dont want to click run on macro to start it. I have if statement settled but when I switch scenes nothing works.
sketta
Thank you for this plugin
It would be interesting to add a "Monday to Friday" feature under "if" "date" option.
Kindly regards.
DiscoJimbo
Hi. Despite looking through the forum I can't figure out how to get my Advanced Scene Switcher scene sequence macro to loop. I'm using ASS 1.22.1 & OBS 29.1.3 on a Windows 11 laptop. I just want the sequence to start again when it gets to the last scene. I did try the 'sequence' tab way but it doesn't seem to let me sequence my scenes as I want to. Thanks in advance for any help.
PNO
I would set up a timer with a fixed duration with automatic reset of timer checked, when the duration condition is met, trigger the above macro to play.
I would do it completely differently. Instead of having a single sequence in a single macro with Waits in between, have a bunch of macros that each does only one transition. Or perhaps a hybrid. You only really need 2 macros to make this concept work.
This is already a loop, because each one switches to the other. Of course, you can make the loop as long as you want, with different wait times in the conditions. Each one goes to the next, and that last one simply goes to the first one.
A huge advantage of doing it this way is that it's also easy to manually escape the sequence, just by switching to something that's not in the sequence. Or you can jump to a particular point in the sequence just by manually (or automatically by other means) going there. A bunch of Wait actions forces you back to that exact sequence when each of the wait timers runs out.
A disadvantage, and why you might want a hybrid, is that you can't repeat the same step at different points in the sequence. If you use variables, you can, but then you actually have to simulate the function in your head while keeping track of the value of that variable, which takes a lot more effort than just reading it off.
So a hybrid might have a sequence of Wait steps, but not the entire sequence, in one macro, and another macro uses the logic shown here to continue that sequence with some more Wait steps. The Wait step that would have been in between, gets converted to a condition timer in the next macro, which is waiting for the last step of the previous one to be active for that time. 2 of those can loop, simply by having their last steps switch to what the other one is waiting for.
BioFUSION
Not sure if its possible, anyway to cycle through multiple actions? Like, say the top box is setup with a hot key... If I have 4 different filters, could I cycle through each one, each time I hit the hotkey?
