Nucktrooper
Since the old tabs are deprecated, is there a way to switch a scene according to a file content with the macro ?
I've only found a way to switch to a specific scene.
Nucktrooper
I see we can also use this plugin to trigger other actions than switching scene.
Is there a way to change the monitor type of audio sources ?
I would like to be able to switch my playlist between "monitor and output" and "monitor off" when I have to focus.
What is the difference Source Active and Showing like this picture?
I want to automatically stop streaming by a condition, not fixed time. Can I use source change or anything else?
Can you elaborate on what the condition is supposed to do / what the circumstances are in which you want to stop streaming?
As far as I understand a source can be active, but not visible.
A source that is showing is always active.
Depending on what you have in mind with your condition you might also want to have a look at "Scene item visibility".
The file tab is still available but hidden by default.
Uncheck the following option on the General tab to show it again.
That is not available in the current release.
If you don't mind using a pre-release version however the option to do so is available in this build:
Here the "Audio" action (and condition) support setting monitoring options of audio sources.
Note that you have to be logged into GitHub to be able to download this build.
If that should be a problem let me know.
rades
Hello friends, I am about to start a podcast with my partner and I want to automate the scene changes every time it detects that the microphone input is coming from her or mine.
The problem I have is that sometimes the image flickers, apparently it doesn't detect which scene it should be showing and the change it makes is immediate and the screen is flickering.
I also want every once in a while to ignore that and show a third scene that would have a general camera only for a certain amount of time. But I can't do it.
How could I solve this?
Next question/issue. Wondering where the macro settings are located in the config files? I am seeing an issue where my settings from the old version seem to still be present and need to figure out how to remove them. Thanks.
You mean the old tabs? There's a checkbox to show them. (scroll up a couple of posts) Then you can work through them manually and delete everything.
The macros should always show, if they're still there. If not, I'd call that a bug, but a workaround might be to:
  1. Back up what you want to keep, probably manually, as the Export/Import buttons cover everything
  2. Uninstall the plugin
  3. Start and close OBS, so that it doesn't load the (uninstalled) plugin and then overwrites the file without it
  4. Reinstall the plugin
  5. Put your settings back in it
To (somewhat) answer your question, it's part of the Scene Collection. (so you'll have to expand steps 1, 3, and 5 if you have multiple) Where that is in the file system, I don't know.
Thanks for that! Much appreciated.
What is probably happening here, when the image is flickering, is that multiple macros, which both contain scene switches, are active in the same interval.
Thus the first macro is switching to "Scene A" and the the second one is switching to "Scene B" immideatly after that.
I would recommend to set up your macros similar to this example:
To achieve the switch to the third scene something like this might do the trick:
This will switch to the "General Camera Scene" every 1 to 5 minutes and remain there for 10 to 30 seconds.
The exact duration values are of course only examples.
And sorry about the delayed response.
Thanks for that useful plugin!
Is there an opportunity to make an easy schedule by importing a text file that says when to show which scene?
And how can I consider time zones? For example, when a time repeats at the end of daylight saving time, how can I say: show this on 2.30 DST and show that on 2.20 Standard time (2.20 standard comes after 2.30 daylight saving time). All in UTC would be easier. :)
Thanks!
Can ASS be used to restart a VLC YouTube source that has stopped?
Unfortunately I am not sure.
Sorry if this question has an obvious answer, but how exactly can I set up a VLC YouTube source?
Thanks!
I am afraid I don't think what you have in mind is possible at the moment.
Can you give an example of what you imagine this file to look like?
Just in case you didn't stumble upon the "Date" condition type here it is described in a bit more detail:
Thanks!
Try the Date condition first. If it's not enough, I suppose you could use your operating system's task scheduler (all of them have one), or a script of some kind, to create some sort of trigger that AdvSS can pick up. Maybe hotkeys, or write to a file, or whatever.
Lawrence_SoCal
I don't think you have to. A Time based trigger, let's say 2:30am, would simply happen twice, 1 hour apart.
But is that doesn't work you (For keeping track of a specific sequence, ignoring daylight savings time)...uh... why not simply turn off DST at OS level? problem solved
As for mass import of time settings ... @Warmuptill - I'm curious if latest AdvSS (sorry I'm on older version of OBS, so not on recent AdvSS), is the settings export still a text file? if yes, and there isn't a CRC or similar check on import, I'm wondering if a user could write a TEXT manipulation script to grab a AdvSS Settings Export and edit with revised time for Scene change (or whatever) and then User import those settings? [ie, a simple case would be simply replacing all Time triggers (or in Macros if using that) with new times?] just wondering aloud, so to speak
Yes, it is still a text file and you could in theory manually edit it. (Although there will be a lot of "magic numbers" for most fields)
There is no checksum or anything of that sort.
It only needs to be a valid json file.
For example macro only containing a single date condition and nothing else would look something like this:
            "actions": [],
            "conditions": [
                    "collapsed": false,
                    "condition": 0,
                    "dateTime": "Sat Jan 14 03:48:41 2023",
                    "dateTime2": "Sat Jan 14 03:48:41 2023",
                    "dayOfWeek": 0,
                    "dayOfWeekCheck": true,
                    "displayUnit": 0,
                    "durationModifier": {
                        "displayUnit": 0,
                        "seconds": 0.0,
                        "time_constraint": 0
                    "id": "date",
                    "ignoreDate": false,
                    "ignoreTime": false,
                    "logic": 0,
                    "pattern": ".... .. .. .. .. ..",
                    "repeat": false,
                    "seconds": 0.0,
                    "updateOnRepeat": true
            "group": false,
            "name": "Macro 4",
            "onChange": false,
            "parallel": false,
            "pause": false,
            "pauseHotkey": [],
            "registerHotkeys": false,
            "togglePauseHotkey": [],
            "unpauseHotkey": []
It doesn't have to be a User action. There's a macro action now (don't know how long it's been there, but it's there now), to Import settings. Combine that with the Run action, and you can have what practically amounts to a self-modifying program. Good luck debugging that!
Also, @Warmuptill , since the possibility exists to Import settings automatically, is it possible to only have a partial Import? Or does it always overwrite everything? If it's always everything, then there really needs to be an Export action as well, so that an external modification script can preserve everything else.
I kinda like the way that the Behringer X32 and X-Air series of digital mixing consoles do it: an incomplete settings file only replaces what's present in the file and leaves everything else unchanged. Translating that to AdvSS, I think if a Macro name is already present, it should replace that macro, otherwise add it. A separate action would be required to delete a macro, or to delete everything and Import All from the file.
bcoyle
Thanks!
You should come over to the 24/7 broadcast thread
Lawrence_SoCal
Personally, if something like that was to be implemented, I'd want the option of how to handle an Import. There are times when you are intentionally removing stuff... ie when I import settings, the ONLY settings I want are those in the Import.
just pointing out different use case/workflow considerations
